09-30-2012, 10:21 AM | #1 |
Location: Hickory, NC native, but stuck in Valdosta, Ga
Hood Heat Shield
I'm in need of a new heat shield, was thinking of using Dyno Mat (Looking product at Home Depo) etc. I've seen the products on LMC but I'm not sure that I want to purchase there product! Any Ideas please address it! Thanks!!!
10-01-2012, 09:01 AM | #2 |
Re: Hood Heat Shield
What do you mean by "hood heat shield"? Are you talking about insulation on the underside of the hood? What makes you think you need to replace it?
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-01-2012, 09:08 AM | #3 |
I got the LMC factory type insulator, and like it right much...
10-01-2012, 12:44 PM | #4 |
I was wanting to replace mine but I wasnt sure if the LMC kit was a big enough single piece.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
10-01-2012, 04:26 PM | #5 |
It is about the same size as OEM. Only thing about running a shield,... If you blow a hose or develop a heck of an oil leak the fan picks up, it destroys it.
10-01-2012, 08:03 PM | #6 |
That's kind of where I was heading; my truck didn't come with the underhood insulation.
In fact, none of my vehicles have the underhood insulation. Smoke Dog - I'd pull it off and not replace it if I were you. K
10-01-2012, 08:19 PM | #7 |
I removed mine and was gonna flat black underneath but undecided at this point
all of my vehicles have insulation....76 gmc, 2008 silverado and my new 2011 dodge ram hemi
10-01-2012, 10:13 PM | #8 |
what is it supposed to do honestly? Just keep your hood cooler?
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
10-02-2012, 06:51 AM | #9 | |
K
10-02-2012, 08:53 AM | #10 |
My 84 K20 with a diesel has it and I can see the need to cut down on the noise.
Also has extra insulation pieces on the firewall.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
10-02-2012, 09:46 AM | #11 | |
K
10-02-2012, 10:45 AM | #12 |
Weren't they also supposed to supress any fires? I know C5's were designed to where if a fire occured the clips would melt and the insulator would fall down on the motor, hopefully supressing any fire.
10-02-2012, 10:54 AM | #13 |
I don't recall that being a design constraint - but - maybe I just learned something.
Although - keep in mind it was not released across the board; only for the "high end" models like Silverado, which leads me to believe it was not primarily a fire retarder. Maybe a secondary design consideration, but not primarily. K
10-02-2012, 11:00 AM | #14 |
I did not have the insulation shield in my 73 C20 or 76 Scottsdale and they were significantly nosier than my camper special 83 C20 Silverado with the insulation. For the low $$ involved I would have one. However, when the A/C compressor sprays oil it destroys a section of the shield.
10-07-2012, 03:01 PM | #15 |
10-07-2012, 03:18 PM | #16 |
www.classicparts.com sells it and clips if needed
http://www.classicparts.com/1973-98-...ctinfo/38-375/ http://www.classicparts.com/1973-91-...ctinfo/38-386/
10-08-2012, 09:10 AM | #17 |
I'd throw it away and not replace it.
K
10-08-2012, 01:02 PM | #18 | |
Thanks!!!
11-18-2012, 09:25 AM | #19 |
did you ever order this and replace yours?
11-23-2012, 03:34 PM | #20 |
Last weekend I sanded my hood down and flat blacked it, looked okay but with the insualtion holes and a few dings it really wasnt all that appealing to the eye so I went ahead and ordered the insualtion and clips.
Insulation came in wednesday so I installed it today after cutting it to fit.
11-23-2012, 04:11 PM | #21 |
88jimmy, you get that insulation at classicparts?
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
11-23-2012, 04:29 PM | #22 |
88Jiimy that came out nice.
11-23-2012, 05:12 PM | #23 | |
11-23-2012, 06:05 PM | #24 | |
78K & 79C Jimmys
i pulled it out, up here it holds salt and moisture,starts rust under it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-23-2012, 08:05 PM | #25 | |
sneak peek
