Old 09-30-2012, 10:42 AM   #1
weever82
weever82's Avatar
Taking off glue/carpet on cab floor.... Sigh...
I pulled up my carpet to redo my cab mounts and put down dynamat. When I pulled it up I have glue across the entire floor and pieces of the original carpet/ fuzz stuck everywhere. The paint is original on the floor and in great shape so I would rather not take a wire brush to it and tear off all the paint. I know I could prob just dynamat over it but my OCD won't let me!
Anyone use a great chemical to take off sticky/43yr old hardened glue?
Thanks for your time.
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 09-30-2012, 10:51 AM   #2
BuiltwithIvy
Re: Taking off glue/carpet on cab floor.... Sigh...
3m makes a pretty awesome adhesive remover, but if its bad it's probably still gonna take you some time with it and a wire brush
3M(TM) General Purpose Adhesive Cleaner... 3M(TM) General Purpose Adhesive Cleaner...
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 09-30-2012, 11:00 AM   #3
BuiltwithIvy
goo gone is good stuff too, and easily available, but odds are its a 3m adhesive thats been laid down for the carpet, its what I have used in the past because its sprays exceptionally well from a cheap paint gun, and the 3m adhesive remover does a better job on that
1930 Tudor Sedan
Old 09-30-2012, 11:07 AM   #4
FirstOwner69
FirstOwner69's Avatar
I'd try mineral spirits/paint thinner first. It's much more gentle and less likely to affect the paint than Goo Gone. I've messed up some stuff with Goo Gone that mineral spirits would not have affected. Apply liberally and give it time to work. I would not use a wire brush either. May take several applications.
FirstOwner69 is offline   Reply With Quote
Old 09-30-2012, 11:13 AM   #5
sboris
sboris's Avatar
Too bad somebody did that. I don't think the factory ever did that. I could be wrong. Good luck with it..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 09-30-2012, 11:15 AM   #6
FirstOwner69
Correct. GM did not use adhesive.
Old 09-30-2012, 11:22 AM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Anything that chemically removes that old glue will very likely remove the paint as well. Try Acetone or Lacquer Thinner, maybe Naphtha in the form of lighter fluid? WD-40? You can always opt for Methyl Ethyl Ketone or Brake Clean, and dont rule out the Carburetor Cleaner. Most of the above will render your "OCD" quite secondary in the realm of health & disorder issues. Thats to say nothing of the flammable and explosive environment created inside the cab. Heres a healthy idea...Dust Mask, Z-87 Safety Glasses, and the Wire Wheel followed up with some touch up paint?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-30-2012, 01:44 PM   #8
FirstOwner69
If you don't want to remove the paint as you say, do not use lacquer thinner or acetone. I believe methyl ethyl ketone will also remove the paint. WD-40, naphtha and lighter fluid should be safe to use. The paint thinner and mineral spirits I mentioned in my post above are safe, relatively inexpensive, not very volitile and readily available at Home Depot, Lowes and your local hardware store.
Old 09-30-2012, 06:21 PM   #9
custom1970
Member
custom1970's Avatar
I would assume someone used commercial carpet glue. There are some removers out there for that, but they don't work that great. I know you don't want to here this but a razor scraper is probably the only thing that will get rid of it.
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 09-30-2012, 06:25 PM   #10
weever82
weever82's Avatar
Well... it's not looking good. Tried the 3M remover and it was like wiping water on the floor... the goo gone was ok but takes about 30 minutes for a silver dollar size clean area.
I just pulled out the 4" angle grinder with a stainless steel twisted wire brush on it... I will just have to wipe the floor clean when I am done getting the glue off and put down some good rust preventor before the dynamat.
Thanks for everyones input. Just too big of a area I guess.
Weev-
Weev-
Old 09-30-2012, 10:43 PM   #11
Brewski*
Brewski*'s Avatar
WD40 works well. If not use XYLENE but wear gloves and a resperator mask. Some stuff comes right off with a heat gun as well.
Brewski* is offline   Reply With Quote
Old 09-30-2012, 10:54 PM   #12
jstrits
I just went through this a few days ago. Dynamat and thick fuzzy backing. Pulled hard to peel off carpet and was left with a 1" fuzz layer. I spent three hours using a razor blade and finger pressure. left some remining fuzz here and there but used glue with the new carpet from acc and it fit like a glove.
jstrits is offline   Reply With Quote
Old 10-01-2012, 12:10 AM   #13
desertnick69
desertnick69's Avatar
WD-40 it will remove most anything. Let it have time to work!
desertnick69 is offline   Reply With Quote
