Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-30-2012, 02:58 PM   #1
djracer
djracer's Avatar
Adjustable Front Shocks
What front Shocks are yall running? I Think I want an adjustable shock. Is the truck lowered?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-30-2012, 03:37 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Adjustable Front Shocks
I am about to go coil over as it gives more adjustiblity and i lose 77#s of the front . Im not sure if im going with Afcos or qa1 . I am going double adjustable though .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 09-30-2012, 04:53 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I run the single adjustable Qa1 shocks up front...and, yes, the truck is lowered. they were around $90 each.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-30-2012, 09:42 PM   #4
bigboybodry
bigboybodry's Avatar
Qa1 single adjustable stocker stars and my truck is lowered.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 09-30-2012, 10:44 PM   #5
dbmx66
was tight on cash when i bought them but i have competition engineering adjustables. mines lowered as well
dbmx66 is offline   Reply With Quote
Old 10-01-2012, 12:45 AM   #6
djracer
djracer's Avatar
Anyone got a part number on the Qa1's
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-01-2012, 12:56 AM   #7
djracer
djracer's Avatar
Is this the Qa1 you guys are running? If so I like your price better Vin.
http://www.jegs.com/i/QA1/122/TS403/10002/-1
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-01-2012, 08:45 AM   #8
Marv D
Registered Truck Offender
Marv D's Avatar
Not to hijack Kevins thread,, but while were on the subject of front suspension, who makes a decent tubular control arm / coil over package for the 63-67 pickups?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-01-2012, 01:42 PM   #9
bigboybodry
I have been looking at porterbuilt Fabrications front member with coilover and I know that fatman has a bolt in kit also.
http://www.azproperformance.com/Port...ropmember.html
Old 10-01-2012, 01:53 PM   #10
bigboybodry
I called and give them my ride,compressed and extended specs. and they sent me a set. They Have eye bolt holes on both ends and mount in the stock location. I also ordered a reinforcement upper shock plate from cpp.
Old 10-01-2012, 06:17 PM   #11
djracer
djracer's Avatar
How much did that set you back?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-01-2012, 06:58 PM   #12
bigboybodry
I think 300.00 for the pair but not positive its been a while.
Old 10-02-2012, 06:06 PM   #13
vin63
vin63's Avatar
Mine are the STS Series -1574p. It does look these shocks are now around $150 at discount retailers like Summit and Jegs. I checked with my wholesaler distributor and my price is $139. That's a big price jump in the last few years.
Old 10-02-2012, 07:50 PM   #14
djracer
djracer's Avatar
That's close to what I was told. I am just gonna run the Competition Engineering for now. I am about spent out.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-03-2012, 02:33 PM   #15
bigboybodry
I can't find the receipt to save my life and I know I have it somewhere.
I know what you are talking about building the car,truck and my new shop is taking its toil on my funds too!!!
Old 10-07-2012, 05:29 PM   #16
BossHogg69
motor exploder
BossHogg69's Avatar
I'm running Chris Alston DA Varishocks, with a 5" front drop, stock crossmember and CPP upper & lower arms.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
