Old 09-30-2012, 03:43 PM   #1
kcfirstbuild
Simple question : how do I take the antenna base off
Can't figure out how to remove the antenna base from the cowl.
kcfirstbuild is offline   Reply With Quote
Old 09-30-2012, 10:24 PM   #2
custom1970
Member
custom1970's Avatar
Re: Simple question : how do I take the antenna base off
Do you have a pic of it? It should just unscrew. You might have to pull the cowl to get to the back side to get a hold of it while unscrewing the top side. A picture would help...
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 10-01-2012, 08:50 AM   #3
kcfirstbuild
I can get one. Its the original antenna base, there is a jaw or something on the backside of the cowl. The cowl is off, also.
Old 10-02-2012, 11:07 PM   #4
kcfirstbuild
Any other takers ?
Old 10-03-2012, 12:48 AM   #5
schurg
should be a threaded top (where the mast goes in). losen that, it should put slack on the 'jaw' on the backside, once you get enough slack the jaw should be able to be turned vertically to be pulled through the hole. if that makes sense lol. or you can cut the rivets on the sides of the jaw..that'll get her out too
schurg is offline   Reply With Quote
