Old 09-30-2012, 03:53 PM   #1
slammer72
aluminum pro comp heads w/cam 600.00 shipped
i was gonna use these but ended up having problems in the block so i have decided to give up on my engine build and by a crate...so here is a good deal for you...brand new heads never run they are procomps 2.02s just had them checked out and every thing is good to go...new valves and springs to run this cam...cam specs are218/218..452"-452"...can be used with vortec intake or standard bolt intake...drilled for both...add your rockers and go..600.00+the ride... thats heads and cam....any questions let me know...jeremy...600.00 shipped in the us....these are pro set up checked and inspected.
slammer72 is offline   Reply With Quote
Old 09-30-2012, 03:58 PM   #2
slammer72
Re: aluminum pro comp heads w/cam
more pics...
Old 09-30-2012, 05:39 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Do you know the procomp part #? what brand and pn on cam? No lifters? Shipping cost to cedar park Tx 78613 please.
WIDESIDE72 is offline   Reply With Quote
Old 09-30-2012, 05:47 PM   #4
rustyrexiusrodz
i'll get in line if wideside passes
olyhotrodz
rustyrexiusrodz is offline   Reply With Quote
Old 09-30-2012, 05:48 PM   #5
slammer72
Wideside...pc3002..cam was custom grind from a shop called green cam grinding.and for you ill throw in brand new lifters..cam part#ch350_hp1438...jeremy
Old 09-30-2012, 10:59 PM   #6
slammer72
Rustyrex...your up next give wideside till tommorow to reply...
Old 10-01-2012, 12:11 AM   #7
WIDESIDE72
WIDESIDE72's Avatar
Shipping cost to cedar park Tx 78613. Is this a hydraulic flat tappet cam? Just curious about the custom grind since it is jot a split pattern...
Old 10-01-2012, 12:17 AM   #8
slammer72
yep hydraulic cam...im pretty sure I can get all to your door step for700.00 total.
Old 10-01-2012, 12:35 AM   #9
WIDESIDE72
WIDESIDE72's Avatar
Just curious about the custom grind since it is not a split pattern...Also are these the 190 or 210 cc heads? Straight or angle plug? Any idea of the PN?
Old 10-02-2012, 01:16 AM   #10
WIDESIDE72
WIDESIDE72's Avatar
I will pass pm sent
Old 10-02-2012, 08:09 AM   #11
Critterman71
Critterman71's Avatar
Shipping to 48872 thanks
Critterman71 is offline   Reply With Quote
Old 10-02-2012, 11:05 AM   #12
rustyrexiusrodz
i'll take them thanks
olyhotrodz
Old 10-02-2012, 01:15 PM   #13
slammer72
Pending sale to rustyrex...critterman if sale falls through 700.00 shiped
Old 10-02-2012, 02:47 PM   #14
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
I take it these are for a sbc Idf so put me in line please.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino.
Stay Tuned!
1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD!
09 GMC Sierra SLT All Terrain pkg.
2014 Jeep Wrangler Sahara unlimited. ( The wifes ride )
GobbleStalker is offline   Reply With Quote
Old 10-02-2012, 08:03 PM   #15
Critterman71
OK thanks.
Old 10-03-2012, 08:27 PM   #16
slammer72
No word from rustyrex since,ill take em.sent a couple pms...jeremy
Old 10-03-2012, 08:34 PM   #17
HotRod C/10
HotRod C/10's Avatar
Next!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 10-04-2012, 10:05 AM   #18
slammer72
Yep, I have to move on due to no contact...critterman is up.
Old 10-04-2012, 10:08 AM   #19
HotRod C/10
thats a fair call IMHO.
LS SWAPPED
-1976 SILVERADO
Old 10-04-2012, 10:59 AM   #20
GobbleStalker
GobbleStalker Calls
Are these the 190 or 210 cc heads? Straight or angle plug
Stay Tuned!
Old 10-04-2012, 09:59 PM   #21
Critterman71
Let next in line have a shot I scored a good deal on a complete big block ready to go instead of finishing my small block thanks for the shot to buy.
Old 10-20-2012, 04:12 PM   #22
slammer72
600.00 shipped...jeremy
Old 10-21-2012, 10:12 AM   #23
slammer72
I need to move these..575.00 shiped....giveaway price:-)
Old 10-21-2012, 12:40 PM   #24
mahanian
C10 addict
mahanian's Avatar
I'm interested pending a part number for the heads.
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 10-21-2012, 01:39 PM   #25
slammer72
Part# is pc3002..
