09-30-2012, 08:13 PM | #1 |
69-72 4x4 LS Oil pan clearance????
Does andbody know if I change the oil pan on my 5.3 to one in the link, will I be able to run the stock engine cross member in my 4x4 k5?
Check this link from LS1tech http://ls1tech.com/forums/conversion...-oil-pans.html Posted via Mobile Device Last edited by Jdubs71; 10-01-2012 at 10:57 AM. |
10-03-2012, 01:57 AM | #2 |
Collector of Projects
Re: 69-72 4x4 LS Oil pan clearance????
I dont think any of the LS pans will fit the factory crossmember, its just too narrow. You either have to modify it or replace it. Do a search and you'll see some threads on your options...
http://www.speedwaymotors.com/S-B-B-...ount,3273.html $50 bucks (no motor mounts) Last edited by mcmlxix; 10-03-2012 at 03:00 AM. |
10-04-2012, 12:50 AM | #3 | |
10-04-2012, 05:41 PM | #4 |
I, essentially, used a cross member from a '73+ 4x4 with clam shell mounts and an AA adapter. It works great.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
