Old 09-30-2012, 08:59 PM   #1
yellow400ex05
do these trucks when you start them normally have a loping idle?
I'm trying to figure out if my truck has an aftermarket cam in it and when i start it anytime after I start it whether is cold or hot it has a nice little lope to it, a noticeable one, I didn't put this engine together but apparently its a GM crate engine, so i think it might be cammed, but i can't be for sure. when its running and i put the clutch in after I've been driving it'll idle higher and wont have nearly as much lope to it, as if it just idles higher when you've been driving it.
anybody got a video of what these trucks normally idle like when started up? do they lope because they are carbureted?
yellow400ex05 is offline   Reply With Quote
Old 09-30-2012, 09:21 PM   #2
Dieselholic92
Dieselholic92's Avatar
Re: do these trucks when you start them normally have a loping idle?
Bone stock small block Chevys have a relatively smooth idle.
Semi professional heavy equipment operator
Amateur mechanic
Dieselholic92 is offline   Reply With Quote
Old 09-30-2012, 10:34 PM   #3
yellow400ex05
alright because when i start my truck it definitely idles a bit rough
Old 09-30-2012, 10:47 PM   #4
74 stepside
74 stepside's Avatar
If it has a lopey idle then it probably has an aftermarket cam. Make sure your timing is correct too. If you want video, just go to you tube and type in 350 with cam. Theres 100s to choose. See if you can compare.
74 stepside is offline   Reply With Quote
Old 10-01-2012, 08:45 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
yup started cold can sound kinda lopey till it's flowing
but if cammed the sound won't go away
but check timing,vac advance
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-01-2012, 08:51 PM   #6
yellow400ex05
here's an idling video, it doesn't sound too lopey but it chops and it doesnt normally go away ever, this video the truck was hot.
how do i embed a video from photobucket?
http://s296.photobucket.com/albums/m...Picture316.mp4
Old 10-01-2012, 09:06 PM   #7
C-10 simplex
What type of carb you got?
C-10 simplex is offline   Reply With Quote
Old 10-01-2012, 09:13 PM   #8
yellow400ex05
quadrajet its not the factory 350 either, its either a 350 from 1969-79 by the casting number i read, but i cant read the casting code on the front head, due to residue from grime.
Old 10-01-2012, 09:17 PM   #9
mongoose
mongoose's Avatar
maybe an rv cam at most?
what is it idling at? just sounds like true duals with crappy mufflers.. no offense.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-01-2012, 09:27 PM   #10
yellow400ex05
i have no idea and yeah its just running some pipe off the header i'm getting dynomax mufflers welded in.
even when the chambered mufflers were in you could clearly hear a defined lope in the idle.
Old 10-01-2012, 11:36 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
yup sounds lopey....tv speakers suck lol
John
Old 10-02-2012, 12:25 AM   #12
meter swinger
meter swinger's Avatar
Dosen't sound like stock cam or exhaust.
meter swinger is offline   Reply With Quote
Old 10-02-2012, 08:32 AM   #13
tucsonjwt
I have a stock 83 C20 camper special and it has a rough idle for about 5 minutes after cold start, then it smooths out nicely. I have a manual choke, which I use sparingly. If I were to adjust the throttle screw it would not idle rough at all, but I prefer to save the gas.
tucsonjwt is offline   Reply With Quote
