Old 09-30-2012, 09:42 PM   #1
ubtripn
ubtripn's Avatar
Easy fix for Windshield Sprayers!
Yesterday I salvaged a reservoir from a Subaru at the junkyard for 5 bucks. These have a small pump installed right on the tanks. (I also picked up a couple of extra pumps for spare parts.) Anyway, I fastened it on inside of the fender and then wired it. (Using instructions here on the board.) You could wire it on it's own switch as well if you wanted. It works perfect. In the picture above it is a plastic storage box I took out of a Yukon (97 I think.) It can hold tools, oil, you name it. The top of the box is a great place to put screws and bolts while working too. Anyway, thought I would share.
ubtripn is offline   Reply With Quote
Old 09-30-2012, 11:59 PM   #2
airdale94
airdale94's Avatar
Re: Easy fix for Windshield Sprayers!
Cool idea! I need to do something with mine eventually. I've seen those boxes before and forgot all about them.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 10-01-2012, 10:18 AM   #3
Lee H
Lee H's Avatar
I did the same thing with a reservoir from a mid 90s truck with built in pump. Great modification.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
