10-01-2012, 01:39 AM | #1 |
Original Wheels?
Anyone have a set of original, or original style wheels are willing to part with? 16" would be great, but 15s would work as well.
Thanks |
10-01-2012, 04:06 PM | #2 |
Re: Original Wheels?
5, 6 or 8 lug? Stamped steel or rally? Hub cap clips or snap over? there are a bunch on boise CL but shipping would kill you.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
10-01-2012, 04:40 PM | #3 | |
Never knew there were so many choices. The only one I can answer is 6 lug. |
10-02-2012, 01:08 PM | #4 |
Mine are from a horse trailer. Except for my spare which is original type. The original wheels were not designed for tubless tires and they had internal clips for the hubcaps. Tubeless tires will install on the original wheels and often they'll seal ok but there's a missing feature designed to prevent the bead from unseating if the tire pressure is extremely low.
If you have any trailer dealers in your area they might be willing to sell you used wheels for short $$. |
10-02-2012, 01:25 PM | #5 |
I also found in my search for hubcaps for my stock 74 16" wheels that the diameter of the hub cap snap point varies. You need to decide if that is going to be a factor (what caps, if any you want to run). Earlier wheels are also narrower affecting the tire size you can run. When you look at trailer wheels check the weight rating, some may fit but are only rated for light weight trailers.
10-02-2012, 01:53 PM | #6 |
Not original,but summit racing carries a nice set of ralley wheels made by wheel vintiques that are made like the original ralleys.I got a set of 12"x15" and a set of 6"x15" you can get any size you want made to your order and the price is real hard to beat,I use summit's brand rings and caps half the price of anybody else and free shipping.I got the spinner caps and they are steel not plastic,ole yea did i mention the part about free shipping lol,good luck in your searches
10-02-2012, 05:44 PM | #7 | |
10-02-2012, 07:43 PM | #8 | |
Thanks 1p2m, that is a significant bit of information. Last edited by arturo7; 10-02-2012 at 07:51 PM. |
10-02-2012, 07:52 PM | #9 | |
What rim width would be best if I use a 30 or 32" tire? |
10-02-2012, 09:35 PM | #10 |
Some of the later chevy rims fit they made six lug wheels to 70 or 71. Toyota has six lug on there trucks also weather they fit I am not sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 Last edited by Rude Dude; 10-02-2012 at 09:35 PM. Reason: spelling |
10-03-2012, 02:43 AM | #11 |
Man, it seems like every detail I look into ends up being a rabbit hole...
I should be looking for 15 or 16" on 5.5, 8" wide, with a 4" offset? Yes? No? Go fish? |
10-03-2012, 11:51 AM | #12 |
Rim width and tire size go hand in hand. Wider tires need wider rims. Most tire manufacturers and many online sources will include a rim width range for a particular size tire.
15" wheels used to be more common than 16" and back then 16" wheels generally received truck type tires. Nowadays there are many light duty pickups and crossover SUV's running 16" and larger wheels so tire choices are greater. But most of the tires are much wider than the original size. An original size tire might be a 205 or 215/60 R 16 (more to follow) |
10-03-2012, 01:54 PM | #13 |
Arturo, I feel your pain. I just dropped off some wheels to get new 215/75/15 tires. Turns out the spare rim that came with the truck was really 16 *DOH!* and another rim is bent, and I haven't even taken the back two wheels in yet... looks like I'm on the same search you are. Maybe I'll try the aftermarket route and get some new wheels that look original. All I need to do is find 6 lug, maybe they could even fit disc brakes...
10-03-2012, 02:53 PM | #14 |
I dug up some research I did on tire/wheel sizes many moons ago.
Original base 6.70 x 15 6.9" wide x 27" dia 15 x 5 wheel Original option 6.50 x 16 7" wide x 27.4" dia 16 x 5 wheel Modern sizes to match original 175 x 85 x 16 6.8" wide x 27.71 dia 185 x 85 x 16 7.28" wide x 28.38 dia 175 x 85 x 15 6.89" wide x 26.71 dia 185 x 85 x 16 7.28" wide x 27.38 dia To run wider tires you would need to get newer wheel, stock or aftermarket. 73 and newer will work with disc brakes because the trucks came with them. For reference (see avator photo) I run 225 x 75 x 16. Tire is 8"" wide x 29.29" diameter and is tucked under the fenders using the 74 axles. Any wider tires and you start throwing mud and rocks up on the body. You can get aftermarket steel rims that are designed to look stock but will accomodate disc brakes.
10-03-2012, 02:59 PM | #15 |
OrrieG- Know where I could get the aftermarket steel rims that are designed to look stock and accommodate disc brakes?
10-04-2012, 01:00 AM | #16 |
http://www.speedwaymotors.com/O-E-St...nch,54993.html
They have the trim rings and caps too. They are not cheap (in my budget world).
10-04-2012, 07:42 AM | #17 |
Unfortunate those only come in 5 lug as far as I've found...
Posted via Mobile Device |
10-04-2012, 09:16 AM | #18 |
wheel / tire edumacation continued:
225/75 tires are about the widest you want to install on an original width wheel. That's the size I'm running. Tire sizes tell you tread width then sidewall height as a percentage of tread width (AKA aspect ratio). Low profile tires are typically /20 /30 /40 while truck tires typically start at /70 and go up. Although a higher aspect ratio seems to indicate a taller tire it's important to be able to check. For example, the original size equivalents above (185/85) have a tread width of 185mm and a sidewall height of 157.25mm while the 225/75 tire has a tread of 225mm and a sidewall height of 168.75mm. Because the treadwidth is greater, the lower aspect ratio tire is taller. This can matter because contrary to simple logic, larger tires are not always more expensive. More common sizes offered by more manufacturers are typically priced better. A 225/75 16 tire is much more common than the 185/85 16. Tires using traditional sizing (31's, 32's, etc) are different. I have much less experience with these and would resort to manufacturer's info to find acceptable wheel width for mounting. Often it is possible to mount a too wide tire on a narrower wheel. When this is done the tread area of the tire inflates round instead of flat. Some people are comfortable altering tire pressure to try and correct this but tire, wheel, and vehicle makers all say "No." for some very valid reasons. Wheel width and wheel offset (or backspacing) serve to position the tire under the vehicle. The considerations when looking at these dimensions are (1) will a change cause a tire to rub, and (2) will a change cause the tire to protrude outside the vehicle. The 55-59 trucks have large fenders that are very open and there's a lot of room underneath for tires. With stock axles, if you're going to use wider wheels you want to look for increased backspacing to help keep the outer edge of the tire under the fenders. Most of the stock steel Chevy truck wheels I've seen up until the late '80s will fit under the fender ok. In the late '80s GM started using huge offsets with wide wheels and those don't fit our trucks correctly. Older Toyota 4X4 and Chevrolet 4X4 share a bolt pattern with our trucks but the wheel centers can be different diameter. Aftermarket wheels are often made to fit both vehicles and I've even swapped some stock wheels between brands. Stock '90s Toyota wheels don't look like original Chevrolet wheels and have no provision for the small center mounted hubcap that Chevrolet used for years. You could probably get a Moon disc or another cap that looks vintage though. Most OEM six lug steel Toy wheels are 15". Yes, when you're on a budget this stuff can become stupidly complicated. The easy answer is break out the wallet and call a company that makes wheels to place the order. The budget method is to understand your options and keep on the lookout for deals. I rebuilt my truck when I lived in eastern MT and there are plenty of trailers around that area which is why I used those wheels. Starting in the late '70s Chevrolet dual wheel trucks use 225/75 R16 tires and there are plenty of old Chevy dually trucks in MT as well. Something has to haul the trailer while the Ford's down. But that's why I chose the tires I used. Unless you're able to buy new, you've got to watch for opportunities with these old rigs. IMO this looks like the buy here pay here answer. http://www.etrailer.com/Tires-and-Wh...r/AM20758.html You should confirm the pilot diameter before ordering by measuring OD of hub or ID of center of brake drum. |
10-04-2012, 01:48 PM | #19 |
My head just exploded. Fortunately I was able to find most of the pieces for reassembly.
So I guess the only way to determine which wheels will allow 30" tires under my truck is by trial and error. Guess I'd better find a local wheel supplier. I don't think the guys at the swap meet take returns... |
10-04-2012, 02:53 PM | #20 | ||
(Hint: A 225/75 R16 is the same diameter as a 30 X 9.50 R15 ) Last edited by 1project2many; 10-04-2012 at 03:15 PM. |
10-04-2012, 04:55 PM | #21 |
A good cheap way to check clearance is to cut out a 30" dia cardbord "wheel" and mount it. Measure to the nearest body parts. Keep in mind back will move up and down and a little sideways (arc from side to side) and front will do the same and turn full lock both ways. I did that when I was shopping sizes for my Chevelle. Mounting the template on the brake drum it is a zero offset. you can calculate the offset you need to center the tire and compare it to stock offset wheels. Even doing that with my Chevelle I found I need to downsize because with the car loaded with people or stuff the tires flexed enough to rub on driveways and around tight corners.
10-04-2012, 05:06 PM | #22 |
Not sure what is meant by "standard sized tire." I would just like to have a larger diameter to keep the motor RPMs down on the highway. I'm using the term "30 inches" as a general description. It is not my intent to specify a particular tire or type of tire.
Also, your earlier post has dissuaded me from going with original wheels. Knowing what I know now, I guess the thread title should be changed to, "What are the specifications of a wheel that would allow me to fit a tire with an approximate diameter of 30" under my vehicle?" Can I assume that these wheels http://www.etrailer.com/Tires-and-Wh...r/AM20758.html fit that description? If so, my question is answered as the specs are listed. |
10-04-2012, 10:47 PM | #23 |
Most tires sold for passenger cars and light trucks today are metric sized tires such as "225/75R16."
Standard sized tires are typically for off road equipment although some light truck tires are manufactured in standard sizes. In typical "tire talk" a "30, 31, or 32" refers to a tire with a standard size such as "30 X 9.50" or "31 X 10.50." If you show up at a tire shop and ask what's available in a 30" tire chances are they'll show you to the offroad or all terrain tires sized as "30 X 9.50." The chart I linked to lists the common metric sizes that are roughly 30" diameter. you could use that chart to write down the sizes of tires you're interested in then see what's available and affordable in those sizes. As long as the center of the wheel fits over the hub of the truck, those wheels should work with a 225/75R16. That would give you a 29 1/2" tall tire which isn't too wide. The tire chart shows other sizes closer to 30" tall but they are also much wider which uses more fuel. 225/75R16 is an extremely common size and you should be able to find plenty of tires ranging from no-name to top of the line. Just be sure to measure that hub before ordering wheels. |
