Old 10-01-2012, 08:49 AM   #1
smartass12
smartass12's Avatar
LS 5.3 in extreme dropmember QUESTIONS from a guy that doesnt know anything
I swear i have searched and cant find a clear enough answer to pull the trigger on motor/trans purchase. (fyi im running nates extreme dropmember, and i will be asking him the same question but i know how busy he is). Originally i wanted to find an ls1/460le combo to run beacuse of looks(manifold)/power and seems more straight forward install for dropmember. But after searching and searching the 5.3 combo seems more in my budget. So far what i understand is i need to replace it with and f body oil pan (i assume the blocks are the same and its just a swap). Here is what i need (swap for dummies) info on..
So the accessories all need to be relocated because of clearance?
At that point will i be better served just ponying up for the ls1 because it will end up being about the same cost at the end? (i know that relative to what i wound be paying for the combos..roughly 5.3 $1700 5.7 $3200) ???
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 10-02-2012, 02:55 PM   #2
OldCreek
OldCreek's Avatar
Re: LS 5.3 in extreme dropmember QUESTIONS from a guy that doesnt know anything
Just an fyi... I have no affiliation or idea about this person but it may be worth a call.
http://slo.craigslist.org/pts/3250784725.html
For me a 5.3 combo was $1300 and all I needed.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 10-03-2012, 08:44 AM   #3
smartass12
smartass12's Avatar
Thanks for finding that for me (miles a bit to high than what i want).
Are you running the extreme drop member?, if so i assume you had to change the location of the accessories with the 5.3 correct?
Old 10-04-2012, 05:39 PM   #4
OldCreek
OldCreek's Avatar
Nah, I'm running ECE mounts and will be using 2.5" drop spindles...nothing extreme here.
Sorry, I can't answer your question, otherwise.
The generic aftermarket pan that you can buy (apparently an H3 pan) sits just at the level of the stock cross member. I think just the little nub from the oil drain plug sits below the level of the stock cross member. Just another fyi...
Old 10-05-2012, 07:13 AM   #5
smartass12
smartass12's Avatar
Sweet..thanks for the info..any bit of info i cant get will help me make my decision on which route to go..leaning in saving up for the 5.7 out of a car..
Old 10-07-2012, 03:28 PM   #6
laynrockers
laynrockers's Avatar
Front what i understand you need a truck accessory bracket to mount the alternator and other accessories in the order. I went with a LY5 5.3 tahoe motor. This way i didnt have to move anything. I am swapping the oil pan with a gen 4 camaro oil pan.
laynrockers is offline   Reply With Quote
