Old 10-01-2012, 07:04 PM   #1
cclaeys
Blazer/Jimmy Suspension Compatibility
Quick question...I have a 1970 4x4 Jimmy, I am assuming that the suspension parts, tie rod ends, etc are all the same as the 4x4 Blazer from 1970? The reason I ask is that parts dont show as compatible when doing part searches, for example Moog ES375R tie rod end. Thanks!
cclaeys is offline   Reply With Quote
Old 10-01-2012, 09:01 PM   #2
AJs72K5
AJs72K5's Avatar
Re: Blazer/Jimmy Suspension Compatibility
Not the answer you're looking for, but some are, some aren't. Really depends on the specific part.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 10-02-2012, 09:26 PM   #3
cclaeys
just trying to figure out whether these will work, 4wd 1970 Jimmy with stock everything, Dana 44 front diff:
Tie Rod Ends:
ES375R
ES375L
Drag Link:
ES2027L
ES2026R
ES362S
Ball Joints:
K8195T
K8194T
Only thing I have no idea about is 4wd pitman arm? These look right? Thanks guys!
