10-02-2012, 12:09 AM | #1 |
rear end I'D help
67 short fleet c10 283 and 3 speed. What rear end do I have and what ratio?
67 C10 swb bored out 350 granny 4 speed I come from a long line of moonshiners |
10-02-2012, 12:19 AM | #2 |
Re: rear end I'D help
Got a picture of it? How many bolts are on the cover?
1970 C20, SM465, Eaton Ho52, HD coils, NO PB/PS/AC, 250 I6, Wood bed. All original minus a tune up! http://67-72chevytrucks.com/vboard/s...d.php?t=545486 Gentlemen wear a bow tie. |
10-02-2012, 12:39 AM | #3 | ||
"I ain't nobody, dork."
12 bolt.
You'll need to pull the cover to be certain what ratio. Or do the tire spin while rear is jacked up and count how many times the driveline turns. It'll get ya close. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-02-2012, 08:57 AM | #4 | |
10-02-2012, 11:52 AM | #5 |
Yes on the seal...But verify which rear end you have, count the number of bolts on the plate...I know I have a 10bolt in my '72...but there are 2 different 10bolts(car and truck) and can be clearly identified by the housing. If you are unsure on how they look or what you are looking for just google it or look in the front of the LMC catalog(pretty helpful info in the front couple pages)
This should get you in the right place. A |
10-02-2012, 12:31 PM | #6 |
Much obliged
10-02-2012, 03:21 PM | #7 | ||
I'm betting if you have a 10 bolt under that '72, it was swapped in. I don't think any of these trucks(67-72) rolled off the line with 10 bolts under them. I could be wrong...
But to the OP... yes, you will need to check to see what you have in case something was swapped out. Gary
10-02-2012, 05:33 PM | #8 |
The 12 bolt aka 3500lb axle was the standard 1967 C10 rear axle with 3.73 gears. 3.07 and 4.11 were also available depending on transmission specified.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
10-02-2012, 11:08 PM | #9 | |
My c20 has a 10 bolt, but it is not a Dana 10 bolt, it is an Eaton 10 bolt, the Eaton 10 bolt is comparable to a Dana 14 bolt. The Eaton is VERY sturdy, just not as easy to find parts for as the 14 bolt
10-02-2012, 11:20 PM | #10 | ||
Under a C20... an Eaton (not an Eaton 10 bolt)... sure. But under a C10... 12-bolt.
If it's a Dana... it's a Dana 60. Not a Dana 10 bolt. Gary
10-03-2012, 08:00 AM | #11 |
10-bolts & 12-bolts,as well as HO52s (with 10-bolt covers) all have Eaton differentials and are referred to as "Corporate" rears. The alternate rear offered was a Dana 44 in 1/2 tons and Dana 60 in 3/4 tons and a rare few 1/2 tons w/6-lugs. The later (73-up) 14-bolt rear is also a Corporate rear,not a Dana.
