Old 10-02-2012, 09:08 AM   #1
ZUBZ
ZUBZ's Avatar
Tailgate mounting help required
As you know I posted some pics and info on my tailgate, anyway I tried mounting it on weekend and cant seem to find the items required to mount it on the bottom that will allow the tailgate to go up/down
I suspect it needs to be like a spring loaded round bar to allow it to be pushed in to allow mounting of the tailgate...
ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa
My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560
ZUBZ is offline   Reply With Quote
Old 10-02-2012, 09:41 AM   #2
Daddy Brim
Daddy Brim's Avatar
Re: Tailgate mounting help required
Bolt up one hinge,put on tail gate. Put hinge on other side and bolt up. No spring that I'm aware of.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 10-02-2012, 09:48 AM   #3
ZUBZ
ZUBZ's Avatar
Thanks Daddy Brim,
But mine has holes on both ends as if a rod suppose to go inside....
Looking at your gate it sort of slots from the top mine does not...
I can take close up photos to show you....
Old 10-02-2012, 02:59 PM   #4
blackdawn
sounds like someone may have played with your tail gate previously, but the pictures that daddy brim show are correct, no springs or rods, just a cap on each side that it rotates on
1969 c-10 short bed stepside - work in progress
blackdawn is offline   Reply With Quote
Old 10-02-2012, 03:04 PM   #5
ZUBZ
ZUBZ's Avatar
I will post close ups, the tailgate is flat and doesnt look like cap ends were ever installed....I suspect something could have been removed on the bed. ...
Old 10-02-2012, 03:29 PM   #6
blackdawn
ah i just went and looked at your other post, sorry i didn't realize your tailgate isnt the stock one for the US atleast so at that point i am unsure of how it would mount, sorry.
Old 10-02-2012, 03:37 PM   #7
blackdawn
when these trucks where imported to mexico they sent them over with out the beds so they would only get charged export/import fees on parts rather than a whole vehicle, and then they put on a bed they made in mexico which was different. so i would suspect they did something similar to canada. unfortunately there really isnt a lot of info on those, but everything else about the truck should be the same as the US
Old 10-02-2012, 03:44 PM   #8
67chevemall
67chevemall's Avatar
Got me looking now! Mine is put on with a big allen key bolt......
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-02-2012, 03:57 PM   #9
blackdawn
the US stepside beds are done with a round slug with a tapped hole in the middle, which you put into the tailgate and then put a bolt in from the outside. they give you a whole at the bottom of the gate to attempt to hold the slug in place while bolting to it. that one is a pita.
Old 10-03-2012, 05:26 AM   #10
ZUBZ
ZUBZ's Avatar
Do you perhaps have photos of this setup?
Old 10-03-2012, 11:03 AM   #11
blackdawn
i dont have any pictures myself of them, but lmc has a somewhat decent pictures of what im talking about
Old 10-03-2012, 11:30 AM   #12
67chevemall
yep thats the one. Just have a nice black hardened steel allen key bolt in there.
Keeps the bastards from walking away with the tailgate easy pesy.
Old 10-05-2012, 05:51 AM   #13
ZUBZ
ZUBZ's Avatar
Guys here are pictures of my tailgate and mounting section on the truck, as you can see on the truck side I have added 2 white lines showing the ridge it has. I just dont see how these got mounted
Old 10-05-2012, 06:34 AM   #14
Crash_OK
Crash_OK's Avatar
Looks like there might be a thick layer of "Bondo" on top of the bolts.. Hard to tell from the pictures.. but it sure looks like it..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 10-05-2012, 07:38 AM   #15
ZUBZ
ZUBZ's Avatar
Mark, that is definitely not bondo, its actual factory welded metal........
Old 10-05-2012, 08:27 AM   #16
Crash_OK
Crash_OK's Avatar
I apologize; I did not read your thread in depth enough. Below are pictures of how the 67-71 USA fleetside attaches. Good luck with your build.
Have a great day..
Mark
Crash's 69 4x4 SWB
Old 10-05-2012, 09:05 AM   #17
ZUBZ
ZUBZ's Avatar
No worries Mark.
I see there are 2 holes below that big hole, do you think I would need a bracket down there to mount the tailgate?
What confuses me is I do not know what that big hole is for....
Old 10-26-2012, 08:53 PM   #18
German_AC
German_AC's Avatar
Hi ZUBZ, Dan 67c10rustbuket contacted me via PM about this post, since your C/10 seems to have similar tailgates like ours (Argentina).
I have no information about in my books, and mine is a C/30 flatbed, so no tailgate, but a friend of mine owns a 76 pickup and he help me to get you a few pictures of the part used in Argentina.
You can see it has a big hole on top, and two small holes on the bottom.
I hope this helps.
1970 Chevrolet C/30
1972 Chevy Nova SS Coupe
1977 Chevrolet C/50
1995 Chevrolet P30 - Grumman Olson Route Star
German_AC is offline   Reply With Quote
Old 11-11-2012, 01:58 PM   #19
ZUBZ
ZUBZ's Avatar
I hope this helps.
German AC, thanks so much for the information and images, this looks exactly like item I require, if you look at my pictures you will see the 2 holes which matches these holes, do you perhaps have some part numbers for these or know what they called ??
Old 11-20-2012, 07:18 PM   #20
German_AC
German_AC's Avatar
Sorry, no part number. I guess you will have to do it yourself.
Even here in Argentina this part is impossible to find.
1970 Chevrolet C/30
1977 Chevrolet C/50
Old 11-21-2012, 04:49 AM   #21
ZUBZ
ZUBZ's Avatar
German AC, I thought so. I have been doing some searching on the net and you can hardly find any info on these. Is it possible for you to trace the size and shape out on a piece of paper and scan and email to me, this will help me get somebody to fabricate the part ?
Any help would be greatly appreciated.
Old 11-22-2012, 06:19 PM   #22
German_AC
German_AC's Avatar
Sure, no problem. Next time I see my budy I'll do it and post the info right here.
1970 Chevrolet C/30
1977 Chevrolet C/50
Old 11-23-2012, 04:47 AM   #23
ZUBZ
ZUBZ's Avatar
German AC, thanks, you are a good man.
Old 12-07-2012, 04:54 PM   #24
77shortstep
77shortstep's Avatar
HOPE THIS HELPS
77 CHEVY - SHORT BED STEP SIDE 2WD
02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT
77shortstep is offline   Reply With Quote
Old 12-10-2012, 03:01 AM   #25
ZUBZ
ZUBZ's Avatar
Thanks 77 for the info, however my question is more relating to the template of the hinge, I showed the picture to an engineer but he said if I can get a template of the hinge and some measurements it will be a lot easier to feed this into his computer program so that we can fabricate the item.
