05-29-2003, 12:09 AM | #1 |
Sleep-Deprived
Pulled my rear diff. cover tonight
Removed the rear differential cover to check things out tonight.
The ring gear read 381903 9.37 GM 3-69 2 37 divided by 9 = 4.11 This is behind a 292, 4 speed & 1 pc. driveshaft with "4x4 tires". Tires are 31 x 10.50 R 15 LT's which has to be throwing the speedometer off. (I'm guessing) What tire is closest to original on the 2WD 1/2 tons? Also, is this a posi? Gears have some pitting, so I may be in for replacing them |
05-29-2003, 12:13 AM | #2 |
Sleep-Deprived
ouch, what happened to the pic
Do photos get compressed on here?
One more time... |
05-29-2003, 12:18 AM | #3 |
Does appear to be an Eaton posi
05-29-2003, 12:19 AM | #4 |
PROJECT 7DEUCE
The 2nd pic look's to be a posi or limited slip of some sort.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-29-2003, 12:40 AM | #5 |
Sleep-Deprived
I'll try to get another shot tomorrow nite
Thanks for the replies, I'll take new photos and see if they get chewed up when post. I can barely see anything on these.
Any comments on wheel & tire size are welcome. |
05-29-2003, 01:28 AM | #6 |
pitting
Pitting on the gears won't hurt as long as it's not howling too loud. Pitting on the bearings is bad news.......Zoomy
05-29-2003, 09:41 AM | #7 |
Prestige Worldwide
Just for future reference, jack the rearend up and you can spin one of the axles forward, if the other side turns forward too then you have a posi. Thats just an easy way to tell if your not sure.
Jason |
05-29-2003, 02:33 PM | #8 |
SLICER AND DICIER
Not true. I had a factory posi in my 72 and if you spun it forward the other would go oppisite. I was told this was a GOV lock posi that is factory and not all that great, so when I blew the spider gears in a million pieces I put in a new Auburn posi and 4:11's. Now when you spin it forward then the other spins forward a TRUE posi.
01 Tahoe 22's 2/4 drop and tv's 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
05-29-2003, 02:41 PM | #9 |
Prestige Worldwide
So your saying a true posi spins both forward huh...... how about that........
05-29-2003, 04:07 PM | #10 |
Fabricate till you "puke"
yup, thats an eaton unit. I agree with ZOOMY......the pitting on the gears wont hurt you ,as long as they arent howling. By the looks, it probably wouldnt hurt to have a look at & or replace bearings tho. good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
05-29-2003, 11:19 PM | #11 |
Sleep-Deprived
Thanks All for the comments, I guess there may be a better test for a posi - involving high rpms and a lot of smoke
I think I'll go with your recommendation CrazyL after some more looking at the steps in bearing replacement. I had some noise in the driveline somewhere and planned on just the u-joints. Bearings are cheap in the 1/2 ton, but how many tools will I have to buy to redo them? I really appreciate the comments on the pitted ring & pinion gears, that will save me $250 for now... |
