Old 10-02-2012, 01:49 PM   #1
JCampbell
Suburban Fuel Tank Transplant
Looking for information on transplanting a 30 gal Suburban tank into a shortbed pickup? Did a search, but didn’t find what I was looking for.
JCampbell is offline   Reply With Quote
Old 10-02-2012, 09:21 PM   #2
mopar346
Re: Suburban Fuel Tank Transplant
This sounds interesting, mine is a LOOONG bed but I would love a 30 gallon tank. If I may ask what year/model suburban did they come in?
mopar346 is offline   Reply With Quote
Old 01-05-2013, 08:50 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I assume you mean the 28 gallon tank this is the write-up I did:
http://www.captkaoscustoms.com/blazertank.html
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-05-2013, 10:30 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Nice any pics of how the fuel filler was ran? Or all finished with bed on it?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-09-2013, 02:22 PM   #5
Captkaos
Captkaos's Avatar
Never got any finished pics from this one, but I am finishing up my 1987 R10 Conversion truck on my forum and it has the same setup, there will be pics of it when it is completed.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-09-2013, 07:34 PM   #6
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Suburban tank is next on my list, I'm curious if it could be mount'd side way's so the filler is piont'd to the rear. my bed floor is raise'd 7.5" and I want the fill cap behind the tailgate.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-09-2013, 07:44 PM   #7
INSIDIOUS '86
Wasn't there a big tank option? My blazer has a 31 gal tank listed on the spid
Old 01-10-2013, 01:02 AM   #8
thrtsxchambers
thrtsxchambers's Avatar
Here are the options and measurements for the squarebody Blazer/suburban tank. I'm looking at doing the same thing to replace my fuel cell. My gas filler is behind the tailgate as well and I need the filler to aim back. I have checked around and most salvage yards have the tanks for around $100.
http://www.lmctruck.com/icatalog/CSB/full.aspx?page=143
thrtsxchambers is offline   Reply With Quote
Old 01-10-2013, 02:13 AM   #9
Bloodhound
I'm putting in this 31 gallon Blazer tank in my 81 C-10 longbed in place of the 16 gallon fuel cell I have in there now. Still trying to work out new mounting brackets though.
Bloodhound is offline   Reply With Quote
Old 01-10-2013, 02:31 PM   #10
maxxxy
maxxxy's Avatar
I have the blazer tank on my truck, but i mounted it from the top of the frame for extra ground clearance. i think you could make it work with it sideways, but all the hoses and stuff would be clocked facing towards the rear too.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 01-10-2013, 03:46 PM   #11
JCampbell
I found the big issue for me on this was the fuel fill dilemma. At first I thought I could run the fuel fill to the rear and do a flip up license plate deal, but it won't work because the bumper is lower than the top of the tank.
I wasn't willing to weld in a new fuel door on the side of the bed and I didn't want to put it in the bed floor. The taillight trick is cool, but way beyond my fabrication skill level.
Old 01-10-2013, 04:25 PM   #12
Captkaos
Captkaos's Avatar
It is too long rotate to the side. The tank is aready close to the pumpkin in the normal rotation. Turning it around is going to be an issue as you would still have to cut your bed sill if you want to aim it back, or if you aimed it up you have to notch the bed sill. The way it is ran is the best option.
On this one it was ran to the side and turned up in the corner of the floor...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-12-2013, 02:49 PM   #13
v30crewcab
v30crewcab's Avatar
I want to make my driver side tailight flip open, for a filler neck. anyone done that before? think it would be sweet for the rear tank.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-17-2013, 11:16 PM   #14
Captkaos
Captkaos's Avatar
There is a write-up of the tailight mod here somewhere.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-17-2013, 11:36 PM   #15
kalbert
I was kind of figuring on cutting in the filler door in a Blazer like location behind the wheel. Filler doors are ugly yes, but it seemed like it would be fairly simple.
kalbert is offline   Reply With Quote
Old 01-20-2013, 09:10 PM   #16
jitteryguy
GoatLube Experss
jitteryguy's Avatar
my bed floor has been raised 7 and half inch's so up and down space is not an issue at all, but I am want'n to do this when I convert to short bed so the length may be an issue .
for the filler cap I want to run it the new filler panel that will be between the floor and the botom of the gate.
'85 1/2 ton CCSB
'92 S10 350/350
