Old 10-02-2012, 04:31 PM   #1
legendman
legendman's Avatar
700r4 speedo gear help
Hi all, I replaced a th350c with a 700r4 in my 84 C10 and the 700r4 I put in is out of a 89 C1500 with a electric speedo. I got the reluctor off the output shaft. I know to find a older 700r4 with a cable driven speedo setup.
But I have no idea what number teeth drive and driven gear I need.
Plus I don't know the rear end ratio and I think I am going to need this info figure it out. Anybody out there know what they have for the speedo gears?
Also I wonder if the gears off the old th350 will work?
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 10-02-2012, 05:45 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 700r4 speedo gear help
Plug in your info here: http://www.tciauto.com/tc/speedometer-gear-calculator
Find a combo of drive and driven gear to find the closest whole number.
700R4 and 350th gears are the same.
You can go to any dealer for the gears. Pricey though. ebay and other sources are cheap.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-02-2012, 07:18 PM   #3
clinebarger
TH350 & 700R4 Driven gears do not swap. Usually the TH350 drive gear doesnt have enough teeth to work on a 700R4 (need atleast 15 tooth) TH350 can be as low as 7 tooth.
http://www.transmissioncenter.net/sp...n_______va.htm
In your glove box....There will be 3-digit RPO codes, Give me the one's that start with G.
clinebarger is offline   Reply With Quote
Old 10-02-2012, 07:44 PM   #4
legendman
legendman's Avatar
Code sheet is gone.. nothing in the glove box and it looks like it may have been on the l/s inner fender at one time, I can see the outline of the sticky stuff where it was attached.
Guess I have to pull the rear cover.
Old 10-02-2012, 08:20 PM   #5
clinebarger
Gear oil probably needs changed anyway.
Old 10-03-2012, 08:34 AM   #6
legendman
legendman's Avatar
I have a transfer case that was on the back of another 700r4, I wonder if that speedo gear setup might work.
Old 10-03-2012, 11:39 AM   #7
Ski-me
Ski-me's Avatar
I converted my cable driven speedo from an 89' to the electronic version of the 90-91's.
When I pulled my original NP241c off, I had a blue drive gear and a green driven gear (I think I said that termimology correctly)....
My truck came with 350 TBI, 700r4 tranny, 3:42 rear axle and 31" tires as a reference for you.
If you have interest, here is a LONG write-up I did on CK5 with a lot of pics....
http://coloradok5.com/forums/showthr...ht=speedo+gear
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 10-03-2012, 11:54 PM   #8
jimbonice
jimbonice's Avatar
Check out the FAQ link on the site. Lotsa good info there.
http://67-72chevytrucks.com/vboard/s...d.php?t=322481
jimbonice is offline   Reply With Quote
c10 and
