Old 10-02-2012, 05:32 PM   #1
dirtybirdindian
dirtybirdindian's Avatar
55 chevy car rearend?
From what I understand it's a good replacement for my 53 3100 as far as fit but is it a good replacement as far as strength and gear ratio.
Have a stock 216 with future plans for a bigger straight 6...250, 261 or 292 possibly.
1953 3 Window Short Box
dirtybirdindian is offline   Reply With Quote
Old 10-02-2012, 10:07 PM   #2
Root2812
Root2812's Avatar
Re: 55 chevy car rearend?
I'm glad you asked this. I was just thinking the same thing yesterday because I know where I can get one and I also heard they fit. I plan to use a 5.3 though. Good luck on your build and I hope someone answers you.
Root2812 is offline   Reply With Quote
Old 10-04-2012, 11:41 PM   #3
JumboAMONGus
JumboAMONGus's Avatar
5 lug car 6 lug truck i seen one laying in a guys yard the other day looks pretty much the same
JumboAMONGus is offline   Reply With Quote
Old 10-05-2012, 09:55 AM   #4
f18delta
Since you are asking, I'd like to throw out the same question, but for a 3600 instead of a 3100.... I'm thinking the gearing alone would be great, but will it hold up the old girls rear end?
Here's something I found the other day when looking for what fits what. I doubt it's a complete list, but it covers quite a few:
http://www.carnut.com/specs/rear.html
f18delta is offline   Reply With Quote
Old 10-05-2012, 09:53 PM   #5
dirtybirdindian
Should I just stop banging my my head on the wall and put the 55 rear in or go find a camaro/nova rearend?
Old 10-06-2012, 01:00 AM   #6
solidaxel
solidaxel's Avatar
If you have one and it is complete it will work
I t is the same rear end i have in my 62 Corvette and I beat on it quite a bit.
There are alot of gear selections and very easy to change the drop out center section, and can be done just like a ford 9 inch, BUT no where as strong. they are the same from 55 to 64 (center sections) but can be pricey if you want Posi traction.
In the mid 6o's I had a 409 4 spd dual quad and the higher gears that were not posi did not stand up to my punishment as the spider gears were the weak link.
Just make sure all the parts are there!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
