10-02-2012, 07:23 PM | #1 |
Truck shuts off after starting...
I have a 71 with a 350, HEI and Holley 3310-4 carburetor. Lately when I go to start my truck it starts up fine but stalls and cuts off after a few seconds. I have to keep my feet on the gas pedal to keep it running. After about 30 seconds or so it stays running. The only thing I've noticed is that the plate on top of my carburetor is always open. Could this be the reason why I'm shutting off and why is it not opening and closing? Any suggestions?
[IMG][/IMG] |
10-02-2012, 07:33 PM | #2 |
Re: Truck shuts off after starting...
It's because the choke (the plate that won't open and close) is stuck open. The choke puts more fuel in the engine to aid in cold starts (just whenever engine is below normal operating temp.).
It almost looks like the choke is mounted to the secondaries?
71 K20 64 GMC mud truck |
10-02-2012, 07:50 PM | #3 |
What could cause the plate to stay open? How can I fix it?
10-02-2012, 07:57 PM | #4 | ||
"I ain't nobody, dork."
The choke has been wired open by the PO. You can get a universal "hand choke" cable from the local parts store and install it. Then you can open or close it by hand. You can also get a kit from Holley to convert it to an electric choke.
I have completely removed every single choke from every single Holley carb I've ever bolted to an engine. Just gotta pump the gas a few times and feather the throttle for about 90 seconds until the vehicle will idle. But if you live where it gets really cold... you might wanna opt for a choke that works. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-02-2012, 08:04 PM | #5 |
You may be right about it being wired open by the PO. But that doesn't explain why it's just starting to stall now when starting. I've had the truck 4 months and it's now only start doing this.
10-02-2012, 08:19 PM | #6 | ||
Because it's getting colder outside. The colder it gets the more fuel and less air required to start the vehicle. That's why a choke flap closes during cold starts. To restrict airflow, but not copletely block it off.
Gary
10-02-2012, 08:33 PM | #7 |
you could also get a cable from any place that sells lawn tractor parts ie ace,tractor supply,true value,and just about any hardware store I find the cables at these places are usually cheaper than auto stores just make sure you get one long enough. they are usually cheap no matter where you go i'm just sayin
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
10-02-2012, 09:20 PM | #8 | |
Also, what is the advantage of keeping it open all the time compared to having it open and close normally? Last edited by Jayschevy; 10-02-2012 at 09:29 PM. |
10-02-2012, 10:42 PM | #9 | ||
No restriction during WOT. It's why I usually mill the choke horn off and blend the inlet too.
Street/strip kinda thing. Gary
10-25-2012, 08:54 PM | #10 |
Is it possible to get the choke to work right again without buying a manual choke or electric choke? How do I get the choke to work like it is suppose to?
10-25-2012, 09:05 PM | #11 |
Buy a rebuild kit. There's a spring inside of the choke, it could be bad. The kit should have instructions on how to adjust it as well.
Personally, I love electronic chokes. I have an edelbrock 1406, 2 pumps when she's cold and she fires and fast idols for a bit, then backs off. No stalling. When she's warm I can turn it off and start it back up on the first key hit every time.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-25-2012, 09:48 PM | #12 | |
Easier to hook up a choke cable. And for the comment about a spring inside the choke. There isn't one in the manual choke set up. |
10-25-2012, 09:56 PM | #13 |
Agreed it is probably the choke causing a hard start, however I had the same symptoms on my truck with an Edlebrock carb. It would start cold and then shut down once it warmed up.
Turns out when the bowl would fill up with fuel the floats would rise to cut of the flow of fuel (as they were designed to do), but the tapered valved would then stick closed due to a lot of dirt in the screens and the truck would run the bowl dry then die. Over time they would eventually release allowing the truck to start again, but as the truck warmed up (i.e the bowl became full again) the fuel would get cut off. Not sure how much different your carb is to an Edlebrock, maybe this will help someone in the future?
________________________ 72 Olds Cutlass w/442 option 69 C-10 Short Bed Fleet 1960 Biscayne Wagon/El Camino 1995 YJ 4.0 SOA SYE on 35s 01 Excursion Limited 7.3 PSD 06 Suzuki DRZ 400S |
