10-02-2012, 10:40 PM | #1 |
Brake line choices for camaro clipped 55-59 trucks
I am wondering what kind of brake line setups folks are using for those that are running camaro front clips. Stock camaro steel lines & hoses or custom braided stuff? I am getting into running new brake lines on my 77' camaro clip...... wondering if I should go stock camaro hardware or go aftermarket all the way. I would love to see pictures of setups that work.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
10-03-2012, 05:36 PM | #2 |
Re: Brake line choices for camaro clipped 55-59 trucks
I'm running a firewall mounted booster/master on mine and have just gone with the basic F/body brake lines across the front and a hard line down the drivers side rail to the rear 'T' on the diff. Let me know if you need a pic?
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
10-04-2012, 12:03 AM | #3 |
Yes, I would love to see a pic of this setup. Thanks!
10-04-2012, 06:59 AM | #4 |
Here ya go, I first hooked up the original front brake lines that came with the clip but then decided to fab new ones. I made them with more curles than Shirley Temple.
10-04-2012, 01:17 PM | #5 |
Now that the above pic is there, mine might make sense. Used all the factory brackets and lines from clip but put a brake T in place of the combination valve(factory) and kept the M/C under the floor. Put my RP valves and proportioning valve in line under the body also. The only thing I won't have is a brake warning light.
10-04-2012, 08:06 PM | #6 | |
10-04-2012, 09:10 PM | #7 |
keep the custom braided stuff to a minimum.
for the best brake system use steel or ss steel lines, 3/16 for disk and 1/4 for drums. even a good braided flex line will give a little, the more you use the more give you will get. using lots of braided or rubber flex lines will give you a spongy pedal. your best off by buying a streetrod kit from a vendor. it will come with 5 foot straight pieces with flares on each end. you could also buy straight pieces and all the fittings separately from napa or your local parts house. get a decent bender and a good flare tool, use double flares only. a cheap one side fits all bender will work but won't make sharp bends like a line specific bender. i bought a ss streetrod kit from inline tube mainly because they are local to me it came with most of the fittings, flex lines and residual valves.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-05-2012, 10:31 AM | #8 |
Here's what I have and you can't see it all. Keep the RP vavles as close to the MC as practical. You can see my front one but not the rear. You can also see the proportioning valve and a little of how I ran the rear line back to the crossmember then used a flexible T line for a late 60's early 70's Ford with a 9" rear. cheapest at an auto parts store and many more than what I used can work. Most of the good parts stores have a thing called a buyers guide that shows pictures. That's kinda what I used, knowing I had a 9" rear. Like Ogre says, get a decent flaring tool and a bender. I used lengths of straight tubing, all 3/16, and fittings from the parts store. The valves and front braided lines came from a hot rod shop that a former student owns. Also the corvette style MC and DD booster. Lots of ports makes the job easier. The more bends you have, the more of a pain it is.
10-05-2012, 07:48 PM | #9 |
Wow!!!! Nice looking chassis. The pictures really help! I was wondering if both the front and rear brake lines need to be equal distance? I see several people putting curls/spirals with the thier brake lines off the M/C. Is this for "shock" or keeping the lines equal in distance? Might be a noob question. Just wanted an insight into the basics.
10-05-2012, 08:15 PM | #10 |
Lines don't care how long they are. It's partly for vibration damping and slack for any movement between cabs/frames, etc. that can move a little during driving. A few bends make R and R easier but on stuff that's bolted solid to the same member, I don't do very much extra. I use the KISS system. Making tubing look good is hard enough as it is.
10-07-2012, 05:56 PM | #11 | |
