10-03-2012, 12:01 PM | #1 |
How do I identify the rearend ratio?
All I know is that I run stock tires on my 68 with a 700R4 and 2000 RPM= 60mph on the freeway. Is this a good balance for fuel consumption vs power? I do mostly city driving. I do not know how to identify what rear end ratio I have.
Also, there is a lot of talk about the lack of aerodynamics causing instability but what about rigs like the Hummer. They are bricks but drive much better. There must be more than just stabilizer bars involved. (Just a learning question.) |
10-03-2012, 12:14 PM | #2 |
Re: How do I identify the rearend ratio?
Best to pull the cover and read the stamped ring gear..... Takes all of 15 minutes and is accurate.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
10-03-2012, 12:16 PM | #3 |
sounds good, thanks.
10-03-2012, 12:32 PM | #4 |
mine does about the same and i have 3.73 gearing but yea opening up and looking is the only way to be sure. if you cant read numbers just count teeth on ring gear and divide by teeth on pinion to get ratio
10-03-2012, 12:44 PM | #5 |
awesome, thanks. So do you feel you have it balanced out pretty well bonnieclyde100?
10-03-2012, 12:47 PM | #6 |
yes it allows me to towing a car trailer easily and still go down the interstate without burning up my engine turning to many RPM. mine used to have a 3.04 in it and that was way to high to tow much. i am only hitting about 2200 at 70mph
10-03-2012, 12:52 PM | #7 |
Good deal, then I do not see a change in my future
thx |
10-03-2012, 02:22 PM | #8 | |
You can read the axle code, but that may not be correct as someone may have changed the gears out. Pulling the cover is the best bet in knowing the correct ratio.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
10-03-2012, 02:39 PM | #9 |
will do, thx.
10-03-2012, 03:52 PM | #10 | |
1 3.06:1 2.25:1 2.48.1 2 1.62:1 1.52:1 1.48:1 3 1.00:1 1.00:1 1.00:1 4 0.70:1 n/a n/a The 700R4 is an 4 speed box with the last gear an overdrive ratio so comparing speeds and RPM between different trucks to guess at your diff ratio won't work particularly well unless you put it in 3rd and you have the same tires. Put the truck on jackstands and either pull the diff cover and check what's engraved on the edge of the ring gear or spin one rear tiire until the pinion goes through two complete turns and divide the number of turns on the tire by two to get the diff ratio. As for stability, if you have good tires you can't get enough horsepower out of your engine to push that brick fast enough to check 'aerodynamic stability'. You'll need a wind tunnel for that. Try NASA Dryden Reasearch center. |
10-03-2012, 04:29 PM | #11 |
Lol - thanks for the data.
10-03-2012, 05:07 PM | #12 |
70+ ( Old Skool Club )
If you haven't pulled the cover off yet use this calculator to find out your rear end ratio. If you are unsure how to calculate your tires height post the size and I'll figure it for you.
http://www.richmondgear.com/101032.html
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
