10-03-2012, 12:55 PM | #1 |
Converting to disk-can I use my original ball joints and tie-rod ends
if I get the spindles off a 76 chevy truck?
10-03-2012, 01:12 PM | #2 |
67-72 parts collector,…
Re: Converting to disk-can I use my original ball joints and tie-rod ends
You will have to use '76 upper and lower balljoints, and outer tie rod ends.
I suggest you skip the '76 spindles. Buy some 63-70 conversion spindles for $219 and BOLT THEM ON! No need to change balljoints or tie rods.
10-03-2012, 01:16 PM | #3 |
ok, thanks.
10-03-2012, 01:22 PM | #4 |
Your other option is to use all of the '76 front suspension.
Everything from the a-arms out. Plus ALL of the steering linkage. I would seriously look at all the donor parts prior to using them. Most are wore out and need to be replaced with new.
10-03-2012, 01:23 PM | #5 |
ahh, good to know, thanks.
10-03-2012, 01:39 PM | #6 |
I just rebuilt my front end and want to stay with 6 lug so I wonder if taking anything off of the 76 in the junkyard would help offset the cost.
10-03-2012, 03:16 PM | #7 |
Msgt USAF Ret
have a look at this.
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042 And this ..........http://67-72chevytrucks.com/vboard/s...d.php?t=456889
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-03-2012, 04:31 PM | #8 |
Thanks! This is going to work perfectly.
10-03-2012, 07:17 PM | #9 |
Ona side note we found that van spindles seem to give a little drop. Also a bolt on situation like the pick up stuff. This conversion is so easy its scary. I kick myself for not doing it several years ago.
10-04-2012, 11:13 AM | #10 |
I am kind of looking to keep stock height but little of a drop in the front wouldn't hurt handling. So how much would you say they drop?
10-04-2012, 01:57 PM | #11 |
I wouldn't say more than an inch. I really cany verify this but the truck seem to sit even lower than it did before the swap. It also has drop srings in it. I t may have been easier to tell with the stock springs. I wonder if anyone else has had this happen. either way it was unintentional but needless to say my son was happy.
10-04-2012, 03:51 PM | #12 |
I hear ya, thanks.
