10-03-2012, 04:07 PM | #1 |
Camaro clip steering question
Does anyone have pictures/measurements for a Camaro clipped 55-59 using the stock steering column of the truck meeting up to the Camaro steering box/shaft.
I don't quite know how much to cut off of the column side.I used the thread from'jalopy journal' but it doesn't have too much info on this part of the build. Would like to see what you guys have done Thanks Posted via Mobile Device |
10-04-2012, 12:06 AM | #2 | |
Re: Camaro clip steering question
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
10-04-2012, 01:05 AM | #3 |
10-05-2012, 12:28 AM | #4 |
Here is my setup. The double U-joint piece is something I bought off a swap meet table for $10. I believe it is from a Chevy/GMC Astro/Safari van. The existing steering shaft is a modified camaro shaft to fit the U-joint piece. The bottom of the stock steering column has a aftermarket bearing installed that supports the factory steering shaft in the column. The "support" bearing you see near the A-arm is something I made to support the U-joint piece from "walking" around. The setup seems to work well.
10-05-2012, 01:36 PM | #5 |
Thanks NW, that all makes sense. Like your use of the parts. Did you keep the original pickup steering column or replace the whole thing with the camaro?
my camaro column was crap so I was thinking of using the stock pickup column. Thanks for the help. |
10-05-2012, 01:54 PM | #6 |
One thing to remember is when you cut the stock column off the gear box cut it long an then after you have the steering shaft out of it cut the tube to the correct length.
The correct length is with enough tube sticking through the firewall to have everything work right but not so long that it creates more of an angle for the U joint below it. If you still have the Camaro steering column you could take it apart and see if you could use the steering shaft from it if it is not a tilt. That would give you the proper end on the bottom of the shaft to put a U joint on without a bunch of hassle. You might be able to use the lower bearing out of the Camaro column or you can hunt down a proper bearing from a bearing house or parts house if that doesn't pan out. |
10-05-2012, 07:42 PM | #7 |
I am using the stock 57' steering column with factory "round" shaft. I modified the "round" shaft at the bottom by using my bandsaw to notch it for the U-joint hookup. It needed a flat side to the shaft in order to work. Hope this makes sense?
10-06-2012, 02:24 AM | #8 | |
After seeing your reply earlier I started looking online and found you were correct about the part coming off of a Chevy van. Went to the wrecking yard and found it. Picked it up (paid $30, but well worth it in my opinion) and looks as if will work just fine with the stock steering shaft on one end and the camaro shaft coming from the steering box. I cut the truck steering shaft right at the stock steering box so I have plenty of material to work with to get it just right. Do you recall where the "holder" that you mounted to support came from? That's what I will be searching for next. Thanks for all the help. |
10-06-2012, 10:40 AM | #9 |
The steering shaft on NW Task Force's truck makes a nice smooth transition from the column to the box and that is one thing that makes for real smooth bind free steering. That's one of the best looking setups I've seen using stock parts and should be trouble free for a long time.
10-07-2012, 06:12 PM | #10 | |
