Old 10-03-2012, 07:24 PM   #1
junk4cash
junk4cash's Avatar
Exhaust Flange Bolt Delimma Help!
Working on my 66 c10. It's not "road worthy" yet, as I still need to tackle the electrical so I have brake lights, so I've been doing the work I can do in the driveway. The old muffler was shot and the exhaust was hanging low and rusted. I tried to remove the two bolts that hold the flange to the exhaust manifold and they sheard off. I was expecting that I guess. My question is, would it be easier to take the manifold off and have my local shop get the studs out? or should I just wait until I have it ready to drive and then take the truck down and have them work on it in the shop? Would I have any luck getting the mainfold off without the bolts shearing off? Thanx very much for your input.
junk4cash is offline   Reply With Quote
Old 10-03-2012, 08:48 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Exhaust Flange Bolt Delimma Help!
I would suggest removing the manifold and getting those broken studs out by whatever method works, either by yourself or having it done at a local shop. It’s going to cost a lot more to have the muffler shop fix the studs since you’re going to be paying them for disassembly work rather than focusing on building the new system.
Also the risk of breaking the bolts holding the manifold to the engine is very low compared to breaking the studs connecting the exhaust pipe. The manifold bolts are threaded into the cylinder heads (not the manifold) and they are also much larger so they rarely snap. Exhaust flange bolts by comparison snap routinely. Over the years they become brittle from the heat and also become fused in the threaded blind holes.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-03-2012, 09:07 PM   #3
junk4cash
junk4cash's Avatar
Thank you very much. Before attempting to remove the bolts, should I use some pb blaster of heat the engine up?
Old 10-03-2012, 09:38 PM   #4
MARTYZ
MARTYZ's Avatar
A good soaking of PB Blaster or ant good penatrating fluid never hurts. Give it some time to soak (overnight) then start removing bolts from a cold engine. Just my opinion.
MARTYZ is offline   Reply With Quote
Old 10-03-2012, 09:53 PM   #5
Racer2172
A little heat with a torch, will help as well. There's many types of penetrant oils that work well too. If you can get it off the truck with out more damage its a lot easier to fix
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 10-06-2012, 01:24 PM   #6
junk4cash
junk4cash's Avatar
Thank you for all the input. Is removing the exhaust manifold a pretty straight forward job? The intake comes off as well correct?
Old 10-07-2012, 11:29 AM   #7
64thunder
its best to remove the intake with the exhaust manifold still attached i have been in this boat as well since one of my flange studs was too short i eventually got them out but then the flange cracked so i bought headers
64thunder is offline   Reply With Quote
Old 10-08-2012, 01:21 PM   #8
1963c-10
1963c-10's Avatar
Would help if we knew what engine your working on. On the 230/250/292, you have an integral intake/exhaust. On a SB/BB, you have seperate intake/exhaust manifolds.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-08-2012, 01:47 PM   #9
padresag
it must be an I6 as he mentioned 2 bolt flange
ron
padresag is offline   Reply With Quote
Old 10-08-2012, 02:27 PM   #10
1963c-10
1963c-10's Avatar
Very true Ron, an oversight on my end. Sorry and thanks. So to answer the question then...yes, the intake will come off with the exhaust manifold. They can be seperated (only 3 bolts). Although I have seen some SBC 2 bolt exhaust manifolds...was why I asked. Some of the LS engines use a 2 bolt flange also.
Old 10-08-2012, 04:14 PM   #11
junk4cash
junk4cash's Avatar
Sorry, 230 straight six.
Old 10-08-2012, 05:25 PM   #12
padresag
that looks like a 265 manifold on the left. I remember those
ron
