10-03-2012, 09:59 PM | #1 |
Trim holes
Hey guys, i've tried every search I can imagine and can't find anything on measuring trim/molding holes. I've got 2 fenders that need trim holes on them. Any help is appreciated.
Thanks, Kevin
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
10-04-2012, 12:51 AM | #2 |
Re: Trim holes
Maybe these pics of the lower and upper moldngs from the 1969 section of the Assembly Manual will help. I didn't see anything similar in the 1970 section.
10-04-2012, 10:55 AM | #3 |
Member
Re: Trim holes
Also remember that the clips can slide if your spacing isn't perfect. Just keep everything straight and I'd recommend drilling through masking tape. Helped me keep the bit from siding around. Oh, and obviously start with a small bit and work up...
Post some pics when you get it done!
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
10-04-2012, 12:58 PM | #4 |
Re: Trim holes
In those trim diagrams, what does it mean like in the first pic when it shows hole #7 as being .120 over .124 in size? Does that mean the hole should be minimum .120 inches and maximum .124 inches in diameter?
Thanks!
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
10-04-2012, 01:08 PM | #5 |
Member
Re: Trim holes
I think your right. Those (#7) are just for the screws so not as critical, but I wouldn't drill them until you have the new screws in hand. Just in case who-ever you get the from changes the size.
10-04-2012, 01:09 PM | #6 |
Re: Trim holes
Not sure, but I believe so. Those holes (#7) utilize sheet metal screws through the trim molding and would be smaller than the others (#6) which utilize clips with studs.
10-04-2012, 01:21 PM | #7 |
Re: Trim holes
Cool, thanks.
10-04-2012, 02:32 PM | #8 |
Moderator
Re: Trim holes
Use a step drill bit to drill your holes
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
