Spring shackles
Ok guys i need some help. I have a 1972 GMC 1/2 ton 2wd and it has rear leaf spring suspension. Does anyone know where I can get some new spring shackles? I've tried LMC and Brothers they don't carry them. Thank y'all for the help.
1972 gmc 1/2 ton long bed converting to short bed ![]() Posted via Mobile Device Posted via Mobile Device |
#2 | ||
"I ain't nobody, dork."
Re: Spring shackles
I might have the stock shackles I took off of my 1972 GMC 1500 Super Custom. I installed a set of 2" drop shackles from CPP in there instead. I just recently moved so I have everything in my shop either still in boxes or in an exploded mess in the corner.
![]() I'll dig for 'em. If I find 'em... they're yours for the cost of shipping. They'll need new bushings. As these were pretty worn out. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Re: Spring shackles
GM just recently depleted these from stock. I know some aftermarket companies make them,just don't know who to tell you.
#4 | ||
Re: Spring shackles
Re: Spring shackles
I saw those but I bought 3 inch drop leaf springs and saw the shackles were 1 to 2 in drop. If I did those would I have c notch the frame since it will make it a 4 inch drop in the rear?
#6 | ||
Re: Spring shackles
Okey doke... anyways... my offer still stands. If I find the stockers off of my '72... you can have them.
Check my reply in post #2. Gary
Re: Spring shackles
Ok if I can't find any I will let you know. Thank you for the help
Re: Spring shackles
i used 73 and up stock shackles.the later springs are 1/4 inch wider so i tack welded two 1/8 inch flat washers to the inside ...the bushing on the frame bracket is the right size .don't remember where i got them but it was brothers or year one i think...wondered why the drop shackles fit early and late but stock didn't....guess the're flimsy enough to tighten that extra 1/4
Re: Spring shackles
I bought new ones from napa for my 71 leaf spring.
Re: Spring shackles
@volksworld I just got some for a 73 was yours about a 1/2 an inch shorter? @bigpaul
i'll check them out thanks. |
Re: Spring shackles
dont think so but truck and leftover parts are in new york and i'm currently in north carolina so i can't check
