Old 10-04-2012, 08:02 AM   #1
NoNeck
NoNeck's Avatar
Looking For Polyurethane Bushings for Trailing Arms
Hi guys,
I need to order some polyurethane bushings for a '70 GMC. It has the coil spring suspension with trailing arms. I was looking on Summit Racing this morning, and found some red Prothane Rear "Control Arm" bushings, Part No. 7-301. A photo is attached showing the bushings.
I guess my question before I put in my order is are these rear "control arm" bushings the same thing as rear "trailing arm" bushings? They look the same, but I was wondering if anyone has used them in the past.
Thanks for any advice.
NoNeck
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 10-04-2012, 08:50 AM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: Looking For Polyurethane Bushings for Trailing Arms
Same thing, just different terminology. I used Energy Suspension bushings on mine, which look the same as the Prothanes that are in your picture. This style of bushing is easy to install. You leave the original "shells" in the trailing arms and just remove the factory rubber inserts. Grease the poly bushings with the special grease and slide 'em in.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 10-04-2012, 11:24 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
I have used these... look like the same thing:
http://www.summitracing.com/search/?...=3-3123g&dds=1
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-14-2012, 12:56 AM   #4
70blackfish
at 13.75....wow thats a good deal...thought they would be more
70blackfish is offline   Reply With Quote
Old 10-14-2012, 03:39 AM   #5
leftcoast66
leftcoast66's Avatar
Does anyone have any sources for the outer metal sleeve. It was removed when the factory bushing was removed a while back. Any ideas for a replacement?
leftcoast66 is offline   Reply With Quote
Old 10-14-2012, 03:53 PM   #6
kaycee
kaycee's Avatar
Just finished up installing my track arm and trailing arm bushings from Pro-Performance.Got them all for under $30 shipped to my mailbox,can not belive the differance in ride.Took all of about 2 hrs,I went to our shop and used a lift or it might of taken a day,track arm was a breeze.I left the rearend in the truck but all in all it was not to bad.The bushings came with a new inner sleeve I just drilled around the old sleeve about half dozen times then smacked it with a hammer fell right out .
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 10-14-2012, 09:54 PM   #7
cubber
You have to order a factory style set to get the steel pieces, and just change the guts.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
