Just a car guy
What spark plugs do you use?
I've always ran ac delcos in my chevy's, but lately, the quality seems to have gone down. I went through about 2 dozen off the shelf, many had badly bent electrodes, some were cocked to the side a lot, some were nearly smashed closed. All were oily and the porclien stained. Some almost looked used.
So, I am thinking of switching brands, and am cuirous what others use. It seems like one of those topics like oil. No one has a good reason why they run one over the other often. It's usually a brand loyalty that is often pasted down. Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
![]() Join Date: Jan 2001
Re: What spark plugs do you use?
NGK, Denso, or Autolite. The Delcos have gotten very expensive for what you actually get. NGK has a good platinum plug for a decent price.
I've tried many brands that were supposed to be better everything from platinum to iridium plugs. But i have come to the conclusion that the ol' champion copper style plugs with the correct heat range are not only the least expensive but tend to perform just as well if not better due to they make more heat ranges of them that you can dial into your setup.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
I switched over the the E3's in my big block and absolutely love them. They are a little more pricey though.
Weev- Posted via Mobile Device
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
72 GMC
I am running E-3's in my 72 350.
Don't really see any difference at all. |
Grandpa in the rustmobile...
ngk run em in everything I guess lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
My brother works at a Chevy dealer so I always get the AC delcos on the cheap. Mine looked fine when I got them out of the box. Maybe its where you're buying them from?
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
AC Delco when I can, Autolite when I can't. Both great plugs. Copper always, swap em out every 20,000 to 30,000.
Oh - and I work at an autoparts store. Sounds like someone did a damaged return/swap, and another person put them back with the new ones, instead of junking them. It sounds like you got some used ones (how they made it past the return is beyond me) but return em and tell them you opened them up and they looked like that. They might give you some guff, but hold to your guns, insist you're telling the truth and if all else fails, demand to speak to the manager. No one puts up that much of a fight that is lying. They usually turn around. Good luck! |
ngk I have never had a problem
Fuzzy |
20' Daredevil (Ret)
![]() Join Date: May 2003
I usually run copper AC Delcos, never had a problem. Once had a set of Autolites and no problems with them either. The only plugs that ever gave me trouble were Champions, and that was a long time ago.
Just a car guy
I thought they were returns as well. Went through a bunch off the shelf and they all looked like this.
Just a car guy
I couldn't see someone returning more then 2 sets of slighlty used plugs.
#13 |
Parts and more parts
I use the ACCEL shorty plugs, which allows for more room around my headers. The plugs last a long time and I have been using them for quite a few years without any issues.
Frank |
#14 |
alot of times especially for a secondary vehicle i tend to run those special"ONSALE" brands
#15 |
![]() Join Date: Dec 2011
Albert Champion Delco
#16 |
Always ran AC Delco R45 TS or TSX with a salvaged HEI distributor and never had a problem. Am trying the E3's based on several recommendations in my new ZZ383 but since I haven't started it yet ( this weekend pray God ) I really can't offer an opinion on them yet. I'll keep the forum posted! Wish me luck!
Posted via Mobile Device |
#17 | |
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#18 |
I am running E3 3.52 in mine with Hei an Love them !
#19 |
I cant say i care too much about my delcos in my 67 but my e3s in my blazer work pretty good.. One thing that keeps me from geting them for my truck is money money money
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
#20 |
Classic Chevy Recycler
I like the copper autolite plugs, or the accel shorty plugs if I am having header issues.
![]() 2004 Chevrolet Trailblazer EXT 1970 Chevrolet C50 1979 Chevrolet C30 Need another 67 or 68 soon... |
#21 |
I ran bosch plugs on my 98 sebring and 69 impala.I like them.Thats what 72 c10 is getting next.
#22 | ||
"I ain't nobody, dork."
If for whatever reason I don't use AC Delco... NGK in everything.
E3 = snake oil. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#23 |
1969 Custom 30 wrecker
AC's in all my Chevy's ONLY.
Put Champions in my 63 once and they fouled in no time. Changed to AC's then and never looked back. ![]()
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#24 |
Cruzin
ac delco never a problem in all my vehicles
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#25 |
Don't run E 3s in new stuff. Had some one put them in his 5.3 and had to change them with in a week.
