Old 10-04-2012, 02:56 PM   #1
KenH303
KenH303's Avatar
Manual choke to Electric choke
Hey everybody,
I was wondering how hard it would be to go from a manual choke to an electric choke. I'm looking at switching to a smaller carb as I have a edelbrock 750 which is just to much for my engine currently. Some of the edlebrock 600's i've been looking at have electric chokes.
1970 Chevy C20
KenH303 is offline   Reply With Quote
Old 10-04-2012, 03:13 PM   #2
bonnieclyde100
Re: Manual choke to Electric choke
should be easy all you need is ignition power wire to power it when the key is on
bonnieclyde100 is offline   Reply With Quote
Old 10-04-2012, 03:13 PM   #3
truckster
truckster's Avatar
Too easy. You just need a 12v source that's on when the ignition is on.
truckster is offline   Reply With Quote
Old 10-04-2012, 03:43 PM   #4
KenH303
KenH303's Avatar
I guess the next question is how hard is it to add a 12v source?
1970 Chevy C20
Old 10-04-2012, 04:08 PM   #5
truckster
truckster's Avatar
It's literally as simple as finding a wire that's on only when the ignition is on and running a splice from there to the choke coil.
If you go to the fuse block, there's a terminal marked IGN. You can run a wire from there if there's not something closer under the hood.
Old 10-04-2012, 04:11 PM   #6
Wrenchbender Ret
If the carb has a manual choke & you want to change to electric, Edelbrock has a kit to change it over.
Wrenchbender Ret is offline   Reply With Quote
Old 10-04-2012, 04:15 PM   #7
KenH303
KenH303's Avatar
Great info everybody you have given a great start on converting "The Beast"
1970 Chevy C20
Old 10-04-2012, 04:18 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
I would suggest looking at the Edelbrock AVS carbs. They are a 650 CFM carb and fit the needs of a truck much better than the 600 does.
Frank
piecesparts is offline   Reply With Quote
Old 10-04-2012, 04:19 PM   #9
GMCJOE
GMCJOE's Avatar
I have a 600 CFM Edelbrock I converted over to electric choke sitting on my engine right now. If I was home I would pull it off and send it to you for a $150 or trade for your 750. I already have a 650 I bought for replacement. But I plan on building the engine up a hair more... If you don't do it before till around the end of January, keep me in mind.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-04-2012, 04:24 PM   #10
KenH303
KenH303's Avatar
Right now I'm just getting an idea on the conversion and I still have to find a carb. I will you in mind GMCJOE as I'm not sure when I will be doing this. I might get the conversion kit now and that way in the future I can just switch out the carb.
1970 Chevy C20
Old 10-04-2012, 07:49 PM   #11
1972RedNeck
1972RedNeck's Avatar
I do just the opposite. I buy electric choke carbs and convert them to manual.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 10-04-2012, 10:04 PM   #12
1967custom
I have an electric choke on a quadrajet and I am considering converting to manual choke. I can never seem to get the electric choke to work to my liking. In my 67 GMC with 6 cyl I have a manual choke that works excellent and I really like it. You could purchase and install a kit to convert and if it does not work good for you then you could go back to manual choke. Good luck.
1967custom is offline   Reply With Quote
