10-04-2012, 04:20 PM | #1 |
preparing the truck for a 2 year hibernation.
I am going to be leaving my truck for the next 2 years. I was wondering what you guys would suggest i do to keep everything in good shape. Thanks
Tyler
1970 GMC 4wd 350 |
10-04-2012, 04:51 PM | #2 |
Newbee
Re: preparing the truck for a 2 year hibernation.
Drain the gas, and coolant (block plugs too). Remove the battery.
10-04-2012, 05:17 PM | #3 |
Two years, huh? Sounds familiar.
The best thing, if you have someone you trust, is to have them start it once a month and let it warm up. Drive it just enough to not let the tires sit in one spot - they tend to get flat spots sitting that long. If not, I would make sure the body is as clean as you can get it, so that any salt that might be hiding is washed off, and then give it at least a coat of carwash hot wax to hold down the growth of rust. A light coat of oil in the cylinders would also be a good idea, to keep the rings from rusting to the cylinder walls. And since you're in Cedar (anywhere in Utah, really) I would try to make sure mice can't get into the cab. |
10-04-2012, 07:46 PM | #4 |
I put mouse poison inside too.
10-04-2012, 08:14 PM | #5 |
Those Silica gel packs like they put in electronics will keep the musty smell out of it too. They will absorb any moisture .. etc.
Maybe put one on a disposable plate or something and sit it under the seat.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
