10-04-2012, 05:05 PM | #1 |
bel air dash?
Just picked up my truck this past Friday ('55). Somebody had cut up a bunch of stuff to make it work on a Dakota frame with almost everything Dakota in it. In doing so, most of my dash has been cut out. I can't seem to find a replacement dash for this truck, but it seems Bel Air dashes are pretty easy to find. From what I can tell in pictures... it SEEMS like it would be pretty easy to make it fit. Am I far off?
10-04-2012, 05:10 PM | #2 |
Re: bel air dash?
(2nd series)
10-04-2012, 05:14 PM | #3 |
Re: bel air dash?
I wouldnt know, but I'd like to see your truck and what had been done to the dash! I would think someone here will know!
dne' ; )
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
10-04-2012, 05:20 PM | #4 |
Re: bel air dash?
haha, the truck doesn't look anything impressive. I bought it in pieces... a "trailer case". It was towed to my house using a flat bed and the bed of my truck... lol. no chassis, no motor, just want i need to build something fun.
10-04-2012, 05:31 PM | #5 |
Re: bel air dash?
best picture of the dash that i can do for now.
10-04-2012, 05:43 PM | #6 |
Re: bel air dash?
Wowzers! sure makes it easy to work on "under" the dash! ; )
I found this on a simple search. You need a entire dash patch panel! ; ) I see potential! dne' http://www.classicindustries.com/truck/parts/17112.html
10-04-2012, 06:06 PM | #7 |
Re: bel air dash?
Kabwe put a 55 dash in his build which looks very nice.
The 59 Impala dashes are also an option. You can also do a smooth dash panel. It all depends on the look you want. http://www.brotherstrucks.com/prodin...number=SDF5559 Kim |
10-04-2012, 07:35 PM | #8 | |
Re: bel air dash?
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
10-04-2012, 07:36 PM | #9 |
Re: bel air dash?
Are you leaving all of that stuff under the dash or pulling it out and going with a heat/ac system that isn't so bulky?
I'd say you are wide open to put what ever dash you want in it as long as it looks good. Or find a cool instrument panel and build around it. If you decide to cut that dash out completely, leave enough of it to fasten the replacement dash to. That makes things a lot easier all around when putting the new dash in. |
10-05-2012, 09:01 AM | #10 |
Re: bel air dash?
Very helpful!! Gives me something to look into.
10-29-2012, 09:27 PM | #11 |
Re: bel air dash?
you should have left the dakota stuff, and the plywood dash
10-30-2012, 12:09 PM | #12 |
Re: bel air dash?
Sure would like to know where those 55 Bel Air dashes are easy to come by at. I can't seem to find one at all around here for my 2nd series!
10-30-2012, 01:28 PM | #13 |
Certified Car Nut
Re: bel air dash?
10-30-2012, 09:24 PM | #14 |
Re: bel air dash?
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
