Old 10-04-2012, 09:23 PM   #1
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Rear axle u-bolts replacements
I have been checking local parts stores for U-bolts for my '69. Not that my old ones won't be usable, but it just seems like the right time to put new ones on when reassembling the rear axle ass'y.
Has anyone bought from any of the suppliers of note? NAPA doesn't list any that are the 3/4-inch diameter, like the OEM part.
Member Nr. 2770
Old 10-04-2012, 09:32 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Rear axle u-bolts replacements
I bought several sets from Summit.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-04-2012, 09:35 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
If you have an automotive spring shop in your area just have them make you some. They may even have some in stock.
LockDoc
Leon
Old 10-04-2012, 09:43 PM   #4
1969K10
1969K10's Avatar
i use a big truck repair shop here locally. they custom bend them for almost nothing.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 10-04-2012, 10:55 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Sounds like the way to go. My son is parts manager for the local public transportation in Little Rock and deals with several shops, daily. Sounds like a plan. Didn't even think along those lines.
Member Nr. 2770
Old 10-10-2012, 11:16 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Got a new pair, custom bent, for $20. A local shop mis-quoted my son a price of $7 each, but reneged on that when they saw what we were after. The guy claimed he'd worked on Chevy trucks for years, and had never seen U-bolts like mine (3/4-inch) diameter material. Then, he said he'd have charged $17 each, but he backed off and that's where the $20 (total) price came into play. I've seen 'em on-line for $14 each, so I feel good.
My old ones are still usable, but I just decided I wanted new ones, since we took the chassis completely apart, sand-blasted and painted each component.
Member Nr. 2770
Old 10-10-2012, 11:29 PM   #7
Square_78
Square_78's Avatar
I was quoted $25 each at two differnt spring shops. Things are always a little more expensive up North here.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 10-11-2012, 05:18 AM   #8
JimKshortstep4x4
The last ones that I bought were $16 each but they were 2" longer then stock.
Nuts and hard washers were in addition but for 3/4" u-bolts I did not think that was too bad.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-11-2012, 06:35 AM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I got new ones for my 1 ton wrecker at Rockauto.com I think I paid around $10 each. They were gold cad and look so nice, I clear coated them! I think they were 5/8 however as the originals were.
They are longer than needed and I will cut the excess off after I torque them down.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
