new gas tank vs. coating old tank?
I need to either replace my gas tank or boil out and coat my old gas tank. I also have an old locking gas cap in the tank I have to get out (lost the key and had to punch it out 10 or 15 years ago - the base fell into the tank). Pricing to clean and coat the old tank is about $170 here in California. LMC has replacement tanks, brand new and pre coated, for about $200. I'm thinking the new tank is the way to go, what do you guys think? Is the LMC stuff good quality at good prices?
1967 GMC 1500 SWB. Driving this truck since I was 14. |
Re: new gas tank vs. coating old tank?
New is the way I'd go.
1971 C-10 307 3OTT |
Too many projects
What is the reason you need to replace the tank? If it's rusted out then go new, but you just want peace of mind, I would clean and coat the old tank. Most new tanks are overseas reproductions that aren't the best fit. OEM seams and construction methods coupled with being cleaned and coated will fit correctly and last a while.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
Look up www.tanksinc.com
There not to far from you, think that is who lmc sells.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
if paying someone else to coat tank better to get new one but if you can do it your self it would be a lot cheaper.
What is the process of cleaning out and recoating the inside of the gas tank? Products to be used?
Thanks, Ryan Posted via Mobile Device |
