Old 10-04-2012, 11:06 PM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Question 5.3L Swap Idle Problem
So, I have been driving my recently "completed" 5.3L swap and it is giving me an issue. When it gets warmed up it wants to die when I come to a stop. It also dies or the idle drops very low after revving it. The mixture seems a little rich also. Has anyone had this issue?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 10-05-2012, 12:11 AM   #2
ls1nova71
ls1nova71's Avatar
Re: 5.3L Swap Idle Problem
Do you have a VSS hooked up?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-05-2012, 12:23 AM   #3
C10_ustacould
I do, but I noticed tonight that the speedo wasn't working. I wonder if it came unplugged... How does it affect idle?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-05-2012, 02:31 AM   #4
ls1nova71
ls1nova71's Avatar
It let's the PCM know when you're slowing down, without it it will take a.second for the PCM to adjust and will cause a stalling problem. Usually more noticeable on rapid decel. If this is a new problem, not int that has always been there, and your speedo used to work then it probably is your problem.
I didn't see the part where you said it will stall after revving it. Could be an IAC problem. Is it DBC or DBW? Have you checked your fuel pressure?
Old 10-05-2012, 07:24 AM   #5
C10_ustacould
I was planning to check the fuel pressure after work today, what should the fuel pressure be with and without vacuum? I will check the VSS pigtail also. Thanks for the info!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-05-2012, 09:16 AM   #6
ls1nova71
ls1nova71's Avatar
Should be somewhere around 58psi . Unhooking the vacuum line from the rail mounted pressure regulator will make it go up but not sure how much.
Old 10-05-2012, 10:17 AM   #7
C10_ustacould
Read a write up this morning that said the 99-02 5.3L with a return style fuel system should be 50-55 psi and around 60 psi with vacuum romoved. You are saying 58 psi... I guess I will see what mine is and go from there, I appreciate your help.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-05-2012, 12:08 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
if its dbw.....seen dirty throttle bodies cause this on dbw systems.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-05-2012, 12:17 PM   #9
C10_ustacould
Mine is DBC.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-05-2012, 09:14 PM   #10
C10_ustacould
Well, fuel pressure is 55psi with vacuum and 61psi without vacuum. The VSS is functioning correctly, but the reading on the electronic speedometer is very low. It reads 10 mph when the truck is going 40mph per a GPS. I suspect that is due to differences in my gear/tire configuration vs the original truck. I also cleaned the throttle body to eliminate that as a potential problem. I have a hand held scanner and it only gives the code P0650 for the Malfunction Indicator Light, which I new was not hooked up correctly. I have an appointment with a friend of Hart_Rod's who is an experienced LSx tuner, maybe he can fix it with a new tune. I don't know what else to do...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-05-2012, 11:53 PM   #11
1BADLS1tuner
do you have the IAT and temp sensors hooked up? 02 sensors?
are you runing SD or MAF tune, OL or CL?
is it 100% stock? If not what mods have you done to the setup? are the pcm and motor from same donor vehicle?
So many things it could be lol, your friend that is a tuner should be able to nail it out!
GL man!
1BADLS1tuner is offline   Reply With Quote
Old 10-06-2012, 12:33 AM   #12
C10_ustacould
Yes the IAT, Temp, and O2 sensors are hooked up. It uses a MAF and has O2 sensors so it is OL... (when warm I assume). It has the GM "hot" cam upgrade and that is all. PCM and engine are from the same truck.
I get what you are saying, I am in research mode collecting info (final drive ratio etc) about the truck so I am ready for the tune on Sunday. Sunday! Sunday! Sunday! Be there!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 10-06-2012, 01:01 AM   #13
1BADLS1tuner
Sunday wont come soon enough for you lol... An experienced tuner will normally catch something overlooked or a bad sensor, ect, pretty fast after hookng up and giving the setup/tune a lookover....
Youll get it figured out!
Old 10-06-2012, 02:01 AM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I didn't see which trans you were running, but assuming its an o/d trans, its possible the bog on deceleration could be related to lockup.
I had a misfire count issue causing the lock and unlcock to screw up on the overdrive. If it doesn't unlock properly on decel, the truck kind of stumbles and trips over itself, sometimes causing it to bog or die if it doesn't unlock fast enough to "catch" itself on the way down.
Tuner fixed it as part of a misfire count issue in the pcm.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-13-2012, 12:36 PM   #15
74project
Had the same problem...if its running rich then it will run 25% richer to account for whatever the problem or code the ecm is having. I went to have a complete scan and my fuel pressure was 10% lower than what it was supposed to be in order to match what the current programmed specs were on the ecm. Runs like a dream now..no more stalls or? wasted fuel....also if it is running a code and dumping the extra fuel at it its fowling up ur plugs and 02 sensors....
74project is offline   Reply With Quote
Old 10-22-2012, 01:24 AM   #16
Ranger6202
Had this same problem when i first fired my conversion up. Turned out being the o2 sensors. My problem was that i didn't have them fully in the exhaust stream since i didn't have my exhaust hooked up (just dangling on the exit of the collector). I'd start the truck up, it'd idle just fine, and then slowly loose rpm as it got warm, and then go extremely rich. It'd sound perfect if i gave it a little pedal but would die when i'd let off. I know you have your o2's hooked up into the exhaust stream, but based on what i saw with mine and comparing symptoms, i'd guess you've got something going on with your o2's. Not to mention i've had a few fuel regulators go out, one went low pressure and the other went high, and i never had idling when warm problems, i would just notice the acceleration would lag when it went low pressure and it smelled rich when it went high pressure. So once again, i'd guess o2's.
Ranger6202 is offline   Reply With Quote
Old 11-16-2012, 03:51 PM   #17
vannatta20
vannatta20's Avatar
My combo with a T56 did this as well. I didnt have VSS hooked up. After I hooked it up and calibrated it to read correctly the problem went away.
vannatta20 is offline   Reply With Quote
Old 11-16-2012, 06:53 PM   #18
C10_ustacould
My VSS has been hooked up the whole time. How did you calibrate it?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
