10-04-2012, 11:47 PM | #1 |
CPP slip shaft Driveshaft and Poly Carrier Bearing
Just like it says CPP Driveshaft and Billet Poly Carrier Bearing Both Brand New
I ended up going with a 3/4 ton driveshaft setup Slip Shaft Driveline (collapsed 33.75” - max expanded 36.5”), CPP price $199 I am selling for $160 plus the ride Carrier Bearing - billet & polyurethane, CPP price $109 I am selling for $75 Plus the ride Photo is the stock photo but both items are brand new and in flawless condition.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
10-04-2012, 11:48 PM | #2 |
Re: CPP slip shaft Driveshaft and Poly Carrier Bearing
10-05-2012, 06:19 AM | #3 |
Amazed Member
I'll take the billet carrier bearing
pm me details
71 LWB Fleetside 1950 3100 Original Project! |
10-05-2012, 09:13 AM | #4 |
pm sent
10-05-2012, 01:19 PM | #5 |
GobbleStalker Calls
I might be interested in the drive line. How does this work considering I have a 2 pc drive shaft now. I already have the billet carrier bearing set up.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
10-06-2012, 06:37 AM | #6 |
Amazed Member
Paypal sent for carrier bearing!
Thank you!
10-06-2012, 07:13 PM | #7 |
This is for the 2pc drive shaft setup. this is meant to replace the rear shaft. It is adjustable so when you change ride height you dont have to worry about changing your driveshaft length and if you ever decide to change it again in the future, you are set, no cutting and recutting.
10-06-2012, 09:32 PM | #8 |
GobbleStalker Calls
K I will take it. Shipping to 13601 NY state.
10-06-2012, 09:38 PM | #9 |
I will get the postage price on Monday and pm you the total! Thanks!
10-07-2012, 09:11 PM | #10 |
GobbleStalker Calls
Sounds good thanks.
