Old 10-05-2012, 01:26 AM   #1
1972SUPERSB
1972SUPERSB's Avatar
Question about fuel lines from tank to fuel pump
I noticed one of the lines was capped off at my fuel pump. I'm thinking its the vent hose if these trucks had one? The fuel pump has the feed from tank, then feed to carb them the other is capped off. There is also a hard line coming up the frame from tank that just ends right before the fuel pump, so I'm pretty sure the capped line goes there. Does anyone have a diagram of where all the fuel lines hook up too? I also looked behind seat and saw 2 lines running up passenger side cab? Thought that was pretty wierd. Any help would be appreciated.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 10-05-2012, 09:05 AM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Question about fuel lines from tank to fuel pump
I believe that is for the charcoal canister that most folks threw away.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-05-2012, 09:44 AM   #3
Lee H
Lee H's Avatar
72s have 3 lines, main feed to the pump, a return from the pump to the tank, and one emission line to the charcoal canister. This ends just in front of the front cross member. Lots of people plug the emission line and toss the canister.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
