Exhaust Manifold Question
Hey all,
I've got a 72 Blazer with a stock 350 sb with stock exhaust. Last night I was changing out the donut gaskets that sit between the exhaust pipes and the bottom of the exhaust manifolds. Got 5 of the nuts off, no problem. The last one decided to seize up. Long story short, the stud sheared off and now I need a new manifold. I'd like to just find one at a junkyard or a pick and pull lot. So, my question is, what range of years did the factory manifolds bolt directly onto my motor? Can I use one from 73-87 truck running a 350? I really doubt I'll find a 72 GM truck with a 350 sitting at the yard, never had that much luck before. Any help would be great, thanks. Oh, and it's a 4wd with A/C. I understand there's a difference.
1972 k/5 Blazer 350V8/TH350/NP205 "The Ox" ![]() |
Junior Member
Re: Exhaust Manifold Question
If you take the manifold off and heat the stud with a torch you should be able to get it out and then you can install a new stud.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
I also realize now I probly should've posted this under engine and drivetrain...sorry.
BB72CHEVKT I didn't even think of that, thanks. I'll give it a shot.Definitely sounds like the cheapest way to go
or you can drill and retap the hole
I just replaced the exhaust on my 72 and broke two studs off the passenger side. I was easily able to drill out the old studs and re tap the threads without removing the manifold. I tried an easy out with no luck. You have to be a pretty good aim to get the bit in the center, I started with a 1/8th" bit and went up to a 3/8" bit. Then I used a 3/8" coarse tap to clean out the threads. If you screw up the hole you can always go up a size.
http://smg.photobucket.com/albums/v655/aaronhero/ |
Newbee
You can also Helicoil the hole, so it's the same size again.
It's not junk yet ![]() |
