backspacing help asap please
i have a 72 c10. i lowered it with belltech spindles so now i need wheels my front 15 inch wheels no longer fit. im ordering 17s b/c i can get free tires at work. the wheels im looking at are 17x8 with 5.25 backspace or 4.5 backspace, and for the rear 17x9 with 5 backspace or 6 backspace. since i have the 72 with the wider rear end i think i need more backspacing is that right? thanks
Re: backspacing help asap please
if anyone can help id be greatful. i need to get wheels ordered so my truck isnt sitting on jackstands in the middle of my garage. thanks
67-72 parts collector,…
![]() Join Date: Nov 2002
I would run the 5" BS on the rear 17x9 wheels,... if that's your best option.
6" BS will be too much. Up front a 5" BS would be better for your 17x8 wheels,... so I guess choose the 4.5" BS if you have to have these wheels. I personally, would grind your lower a-arms so your 15" wheels would work. You never know when you will have to install the spare or other 15" wheels.
The lower control arms isn't the problem. I ground them they clear fine. The wheel is rubbing on my caliper mount on the spindle. I never seen it happen before but it is. It's ok tho I wanted different wheels just wasn't ready yet. Oh well that's life thanks for the reply
Posted via Mobile Device |
Forgot to put I have a 5/6 drop and will have 245/45r17 front 275/40r17 rear. Freebies from work
Old Skool Club
![]() Join Date: Jun 2001
I used a 4-inch BS up front and a 5-inch BS out back, on my '69. Front wheels are 8-inches wide, while rears are 10-inches wide.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
