Old 10-06-2012, 01:40 AM   #1
Secret Squirrel
Secret Squirrel's Avatar
I admit I have a problem!
My name is Squirrel and I am addicted to collecting vintage muscle cars!
I just scored a 70 C-10 Short Step from the original owners grandson! I have the original sales receipt, owners manual, warranty card, and Protecto plate(?). Her name is Charlotte
Body is solid, engine is a 305 (not confirmed numbers don't show up on any engine search web sites L5 _ _ unreadable). It has the small harmonic balancer like the 327 (guy I bought it from said it was a 305, but he also told me it was turbo charged due to the large Eldelbrock carburetor??) It was originally a 6 banger, but now the sbc is dressed with edelbrock 600 carb, intake, valve covers, and camel hump heads.
After much TLC she runs real good (seems to red line at 50 MPH LOL) Originally three on the tree It now has a three speed floor shift (Saginaw(sp?) with 12 bolt open diff rear (373 gears). I spent the last two days changing out all the fluids, flushing the fuel system, rebuilding the carb.
During the first test drive the master cylinder went out. I purchased a re-manufactured one and just spent way too long bleeding the brakes. Short version: Primed the new manual master cylinder bled the rear drivers side, rear pass side, front pass side all went smooth.
When I got to the drivers front it had a ton of air, after one hour we made no progress(actually seemed to get worse). We would loose press then get it back then loose it again.
Fluid is bursting out and burping (line is not plugged), but it as if we are sucking in more air than fluid. There are no leaks in any of the lines leading to to front passenger side and we never ran it dry up top.
Last clue is ... When we removed the cap to check the reservoir the rear reservoir was milky (filled with air). So, did I buy a lemon master cylinder or can a collapsed rubber line leading to the drivers side front caliper cause this? Would appriciate some mentoring!
I am still stoked to have this old girl but she is stubborn as all get out. Any advice or compliments welcome.
________________________
72 Olds Cutlass w/442 option
69 C-10 Short Bed Fleet
1960 Biscayne Wagon/El Camino
1995 YJ 4.0 SOA SYE on 35s
01 Excursion Limited 7.3 PSD
06 Suzuki DRZ 400S
Secret Squirrel is offline   Reply With Quote
Old 10-06-2012, 11:49 AM   #2
slikside
slikside's Avatar
Re: I admit I have a problem!
Can't offer you any specifics on your brake issue, but that is fine looking truck! You have a lot to work with there! Congrats on the acquisition. Someone will pipe up with some suggestions, I'm sure.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 10-06-2012, 02:53 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
A hose can cause problems.Especially if it's 40 years old.I would take the hose loose and see whaether it pushes fluid when slowly pressed.If so I would try a new hose.Probably needs them anyway.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-06-2012, 05:05 PM   #4
Secret Squirrel
Thanks for the advice, I'll get a new hose. If I pump the brakes I do get full pedal. Turns out I probably did not fully bench bleed the reservoir so I'll try a speed bleeder too.
I found some 20" wheels and tires on craigslist that came off a nissan truck, with good rubber for $300 (cheaper than I could get four cheap tires from Pepboys). It was just going to be a temporary fix, but I kind of like the way it looks.
06 Suzuki DRZ 400S
Old 10-06-2012, 05:09 PM   #5
70cst
70cst's Avatar
Looks like a very solid truck
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
