engine mounts
i know the frame or rubber side is different between a small and big bloc but are the clam shell or engine side the same? thanks
Re: engine mounts
You might get the stock SB ones to work, but theres 4 or 5 different heights of clam shells. I hunted around trying to find a BB set for mine and found out this little tid bit of knowledge. And I think the frame sides are the same they just bolt in different holes.
| Bookmarks |
