Old 10-06-2012, 06:09 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
How to install plastic or rubber firewall plugs?
I have both and the plastic ones fit real tight and the rubber are too soft to pound in. Recommendations?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 10-06-2012, 07:13 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: How to install plastic or rubber firewall plugs?
Have you tried lubing them with soapy water.... or WD-40.... or silicone spray?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-06-2012, 07:17 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Re: How to install plastic or rubber firewall plugs?
Well after you spray them good try a little scred driver to it will help push the part that goes inside the metal to hold it in.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-06-2012, 07:18 PM   #4
AirSpeed
AirSpeed's Avatar
Ironically I just installed a couple plugs in my firewall, picked the plugs up at the hardware store and they popped right in without any issue. They fit snug but were very easy to install.
AirSpeed is offline   Reply With Quote
Old 10-06-2012, 07:53 PM   #5
cdowns
cdowns's Avatar
a good quality plastic knife is good for pokin an proding things like that in place and do no damaage
Old 10-06-2012, 09:13 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Should be able to use a piece of string.Use it like you would for a windheild install.That and some lube should work.It also mens thy will not come out easily.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-06-2012, 09:20 PM   #7
ItsRandy
ItsRandy's Avatar
I got some from Brother's Truck parts with 3 little prongs on the back that hold them in the hole. Worked great.
ItsRandy is offline   Reply With Quote
Old 10-06-2012, 11:49 PM   #8
weever82
weever82's Avatar
+1, works great!
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
