Old 10-06-2012, 06:50 PM   #1
medicman775
Back up light assembly
Does anyone know if any vendors sell the back up light assembly? The metal part that screws into body and that the bulb goes into? Can't seem to find it.
medicman775 is offline   Reply With Quote
Old 10-06-2012, 07:59 PM   #2
vectorit
What?
vectorit's Avatar
Re: Back up light assembly
Last time I looked, there were no reproduction units being sold.
I had to scrounge for good used ones that weren't corroded in the bulb socket.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-22-2012, 06:35 PM   #3
gearboxx70
I was able to save mine with a little elbow grease and a Dremel tool. As long as the corrosion is just on the surfaces, a couple wire wheel attachments for the Dremel and a little time make things work like new! After you clean the sockets, put on a thin coat of bulb grease or dialectric grease. This will keep corrosion out, and make for a better contact surface for the bulb.
gearboxx70 is offline   Reply With Quote
Old 12-22-2012, 08:28 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
http://www.ebay.com/itm/1967-1972-CH...sories&vxp=mtr
I found this set on ebay and they may be more but I did not look further.
Good Luck
TBONE1964 is offline   Reply With Quote
Old 12-22-2012, 08:57 PM   #5
vectorit
What?
vectorit's Avatar
Good Luck
Those are for the pick ups.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 12-22-2012, 10:29 PM   #6
budnikguy
budnikguy's Avatar
I have a pair for sale...
budnikguy is offline   Reply With Quote
Old 12-23-2012, 09:51 AM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
My apologies, I get this thread mixed up with the pick up thread on occasion.
Happy Holidays and good luck with your search
