Old 10-07-2012, 09:21 AM   #1
66farmer
66farmer's Avatar
Show me your wiring routeing
It's time to start the wiring I could use some ideas.
1. I would like to see as little wiring as possible under hood.
2. How did you guys go from under dash to the rear of truck with out going through the firewall and down.
3. Did most you guys mount the new fuse box in the old location.
4. Getting the wiring to the front turn signals.
Thanks for the help post pictures if you have them
66farmer is offline   Reply With Quote
Old 10-07-2012, 10:19 AM   #2
CRGRS 66
CRGRS 66's Avatar
Re: Show me your wiring routeing
farmer, I am going to tag along on this so I can get the same advice you are looking for. Thanks for posting this up.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-07-2012, 10:45 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
I think I mounted my fuse box in the same location but not 100% sure about that. I also put in a differnt gas pedal. I used the old gas pedal hole to bring my harness out to the engine compartment and ran the wires between the headers and engine block, I also have spark plug wires designed to run under the headers. For the headlights, I drilled a hole at the top of where the inner fender bolts up and ran the wires under the left inner fender instead. The hood wires come out from behind that and those are the only ones really can't hide 100%. I relocated my batter to behind the cab so no wires there either. This is my result except that I am not totally finished with it. You can see where the wires come out for the hood lights. I hope to redo the brake lines someday and I still need to run some vaccum lines.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-07-2012, 10:47 AM   #4
woodscavenger
woodscavenger's Avatar
that's a work of art!!!
62 C10, LWB fleetside, 350SBC, Munie 4spd,
woodscavenger is offline   Reply With Quote
Old 10-07-2012, 10:56 AM   #5
Chevy Fleetside
Thanks Wood. I will try and get a shot from under the left inner fender. I only wish I had welded in a tube before I painted the inner fenders. I can always epoxy one in to protect the wires or even wire loom.
Old 10-07-2012, 06:25 PM   #6
Mack B
Mack B's Avatar
On question #2. I ran the wires to the rear of the truck, down from the fuse panel and under the door sill to the gas tank area. There was already a 1/2" hole there that I dont know if was factory or not, from there followers the frame rail in the factory location.
Mack B is offline   Reply With Quote
Old 10-07-2012, 11:23 PM   #7
The Sub
The Sub's Avatar
I ran my wires from the fuse box under the fender. My spark plug wires run down the back of the engine and under the headers. i tried to run all my wires from underneath so they would not be seen. i also tried to hide my hoses. my heater and ac hoses run under the fender too. Hope this helps you.
Jim
The Sub is offline   Reply With Quote
Old 10-08-2012, 08:26 AM   #8
66farmer
66farmer's Avatar
Jim
Looks great
Are you talking about under the upper inner fender that square area. If so where and how did you inner and exit the fender area. And did use a conduit in that area.
Thanks for the help
Old 10-08-2012, 10:52 PM   #9
The Sub
The Sub's Avatar
Originally Posted by 66farmer View Post
Looks great
Thanks for the help
Yes under the inner fender. I made a sheet metal channel and welded it under the inner fender and ran my wires to the front. The wires that ran to the back I wrapped in plastic wire loom and I ran them along the inside of the frame.
Jim
