Old 10-07-2012, 11:56 AM   #1
hpcgmc
hpcgmc's Avatar
Rusted floor on my 67
Just starting on my 67 GMC. Pulled out the floor insulation and found rust on both the driver and passenger floor. It's rusted all the way through in places. How is this normally repaired? Do I get a welder to weld in a patch of some sort? Is there a pan type kit that goes over or under the existing floorboard?
Any ideas on options is appreciated. I don't plan on a frame off restoration.
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 10-07-2012, 11:59 AM   #2
c10srule
c10srule's Avatar
Re: Rusted floor on my 67
welding is the best way, ive seen others use rivets or screws, if you go that rought use a good sealer, depends on how big the holes are, they make a whole floor, you can get half floors or if its not to big get some good sheet metal and cut the rust out and weld a patch piece in
c10srule is offline   Reply With Quote
Old 10-07-2012, 02:05 PM   #3
rkintn_68
rkintn_68's Avatar
You can cut out just wat is bad or replace sections , or the whole cab floor , depends on funds or time you have ... here is an idea of some of the cost for
parts ...
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD
70 CHEVY C/10 LWB x 2 ----- SOLD
67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN "
Build thread :
http://67-72chevytrucks.com/vboard/s...15#post6826315
rkintn_68 is offline   Reply With Quote
Old 10-07-2012, 02:11 PM   #4
rkintn_68
rkintn_68's Avatar
Sorry wrong pic ... try this ...
Build thread :
Old 10-07-2012, 03:34 PM   #5
haplis
lmc is a good way to go, you can buy a decent sized piece of sheet metal from them. as far as the floor is concerned it is pretty common to find rust on the floor next to the kick panels. go to www.mobilehotrodrepair.com this guys has some really good videos that show rocker panels and floor being repaired.
haplis is offline   Reply With Quote
Old 10-07-2012, 03:46 PM   #6
ole dollor
ole dollor's Avatar
i guess most of these trucks has or had some rust in different places...welcome to the board from Texas, just try and fix it as good as you can, so it will last a long time.....its a lot better to get all the rust out and replace it with new metal, that way these great trucks will last forever.....
ole dollor is offline   Reply With Quote
Old 10-07-2012, 05:11 PM   #7
88fordf150
88fordf150's Avatar
Great Info! I learned something new.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 10-07-2012, 11:53 PM   #8
hpcgmc
hpcgmc's Avatar
Thanks for the input. The mobilehotrod videos are very cool!
Old 10-09-2012, 11:27 PM   #9
tim21391
tim21391's Avatar
pics pics pics pics.... catch my drift?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 10-10-2012, 10:25 AM   #10
hpcgmc
hpcgmc's Avatar
Pics of my rusted floor.
Old 10-10-2012, 01:55 PM   #11
budnikguy
budnikguy's Avatar
Wish you were closer...I have the majority of a floor in the keeper corner just for someone needing it like you.
budnikguy is offline   Reply With Quote
Old 10-10-2012, 02:02 PM   #12
chill68
chill68's Avatar
LMC's complete floor plan (rkintn 68's pic) is a great buy. I used one on my 68 GMC. Cut the old one out, pop the new one in, and tack away!
1968 GMC 1500 Long Fleetside 327 "The Chillest!"
1971 Chevy C/20 Long Fleetside 350
chill68 is offline   Reply With Quote
Old 10-10-2012, 03:21 PM   #13
1970 C10 MJW
1970 C10 MJW's Avatar
mobile hot rod repair vids are awesome!
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 10-10-2012, 04:03 PM   #14
99-LS1-SS
99-LS1-SS's Avatar
GMC Paul's sells floor pans too.
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 10-10-2012, 04:27 PM   #15
54belair
54belair's Avatar
Im by no means an expert on this, but--------having just paid almost $3K to repair a floor that initially looked much better than yours, my advice would be to do a lot of investigation BEFORE you spend money on repairs.
With the condition of your rockers and the floor at the toe board, I would also say that your lower door post extensions are also rusted away (that you cant tell until you remove the outer rockers.
My favorite saying is that rust is like an iceburg---90% of it is unseen.
You are looking at some extensive floor repairs----it might be more cost effective to find another cab in better shape. The truth is "these trucks rust", so finding one thats never had rust is highly unlikely, but there are better and worse candidates for restoration. Had I known how extensive the rust was in my cab--Id have driven across country if necessary to find a better one, but as we worked on mine--the more we fixed, the more we found. We quickly got to the point of no return--had too much in it to stop. Its rust free (?) now, but the cost was much higher than I initially imagined.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 11-13-2012, 01:10 AM   #16
tim21391
tim21391's Avatar
buy your tins from wes off here.. great guy and great prices... then go to work on it.. i did all the metal work with a few other board members that are from my town.. and after they taught me a bit and what not it all fell into place.. fairly simple
Old 11-13-2012, 01:35 AM   #17
collisioncenter
I can't say that I have ever replaced a floor on these yet....I say that because I will be on my 72. What I can tell you from experience and looking these trucks over very extensively...Replace the entire floor. You get all the braces, inner rockers, and its all new metal. I've done a ton of patches on things, cars, pickups, even vans. After looking at the floor, the extra money it takes to get a floor will actually end up costing you alot less in the long run. I can also tell you that if you are somewhat handy and have some metal working tools (especially a welder) you can install this floor yourself! There are other things out there I would recommend the DIY'r pay someone for. This is something that is very simple and can be done by almost anyone. Take your time, ask plenty of questions and you would have no problem with it. Were all here to help. If there is one thing I know something about its body work!
collisioncenter is offline   Reply With Quote
Old 11-13-2012, 01:44 AM   #18
sduckworth13
sduckworth13's Avatar
Check out my build on the 67-72 builds, I just replaced my drivers side outer floor, inner kick panel, door pillar and outer rocker. I will give you a idea of what is done.
Scott
sduckworth13 is offline   Reply With Quote
Old 11-13-2012, 01:51 AM   #19
sduckworth13
Im pretty new at welding too, I just started welding this year and haven't made it through two spools of wire yet.
Scott
Old 11-13-2012, 08:51 PM   #20
mrich550
i redid the floor sections. inner & outer rockers, cabcorners, & cab supports on my 72 c20 before they offered whole floors. my cousin just did his 72 k10 but he did the 1 piece. definetly spend the money for whole floor... unless your like me & enjoy welding. either way it's a lot of work, just less room for error with whole floor. a few things of welding advice. the cleaner your metal the easier it welds. use .023 gauge wire not heavier ( decreases chance of any warpage) TAKE YOUR TIME. you'll be glad you did
mrich550 is offline   Reply With Quote
Old 11-14-2012, 03:20 PM   #21
orange rumble
orange rumble's Avatar
SDUCKWORTH13,thats DAMN good work dude.
orange rumble is offline   Reply With Quote
Old 11-14-2012, 03:27 PM   #22
sduckworth13
Thank you
Scott
Old 11-14-2012, 04:47 PM   #23
C0UCH
If you are looking to get rid of it, I'm also in need of a lot of floor and am located in Orange.
C0UCH is offline   Reply With Quote
Old 11-14-2012, 05:35 PM   #24
454C10CHEVY
454C10CHEVY's Avatar
It shouldnt be to bad to do it yourself.. were in nor cal are you located?
72 C10 SWB Stepper 350/TH400 (might sell)
70 C10 SWB Stepper I6/4SPD (CURRENT PROJECT)
00 Silverado Rc 1500 2WD 5.3
09 Silverado Cc 5.3 2WD 4/6 DROP
04 Silverado ext 5.3 4WD
454C10CHEVY is offline   Reply With Quote
