Old 10-07-2012, 01:33 PM   #1
Southern Shaker
Thumbs down Radiator hose question?
Do the screw in line to the radiator go over or under the bottom radiator hose? Thanks in advance -Aden
Southern Shaker is offline   Reply With Quote
Old 10-07-2012, 03:47 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Radiator hose question?
I don't understand what the "screw in line" is. Transmission cooling lines?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-07-2012, 03:56 PM   #3
ole dollor
ole dollor's Avatar
can you get us a pic....that might help...
ole dollor is offline   Reply With Quote
Old 10-07-2012, 04:13 PM   #4
AirSpeed
AirSpeed's Avatar
Are you talking about the hose clamp screw? If so it doesn't matter as long as its easily accessed.
AirSpeed is offline   Reply With Quote
Old 10-07-2012, 04:17 PM   #5
Southern Shaker
do these metal lines that screw in to the radiator go under the hose or over it?
Old 10-07-2012, 04:25 PM   #6
ole dollor
ole dollor's Avatar
i would say that put it where it works the best, you may have to bend the metal line some for it to clear the rad. hose. not for sure if it goes below or above, i don't have a auto in mine to go look at, i would just put it where it works the easiest and the best fit....
Old 10-07-2012, 04:29 PM   #7
GASoline71
GASoline71's Avatar
Don't think it matters. Those are the factory transmission cooler lines. As long as the fan don't hit them.
Noticed the big gaping hole in that inner fender under the battery. Mine looked almost that bad when I bought my truck 7 years ago.
Gary
Old 10-07-2012, 05:08 PM   #8
Southern Shaker
Gary
haha Funny Story about that ... back about 3 years ago i sorta cut that out (not knowin what the heck i was doin) thinkin id get a new one i was wrong , Alright thank you guys i apresheate it !
Old 10-07-2012, 05:19 PM   #9
c10srule
c10srule's Avatar
they generally come out under the motor over the cross member under the hose and up the radiator to the fittings, but it really doesnt matter, just need to run them so they dont hit the fanbut with a shroud they shouldnt come close to the fan and dont rub on the frame to cause a hole later and away from headers,they can be fun to run some times, hope it works out
c10srule is offline   Reply With Quote
