mysterious Tranny Question-Please Help.
I went to check my tranny fluid on the 700R4 I have after the engine was warmed up and running and I cannot tell the level. The dipstick has xxxx marks and they definitely have fluid in them because I am able to wipe them dry but there is not fluid on the stick as prominent as there is with oil. I am very careful taking it out, keeping it from hitting the sides and keeping it level and when I do turn it vertical a drop comes off but I am not sure if I am reading it correctly???
There is so little of an amount on the gauge part of the stick. A little history, It is shifting great right now but when I installed it last year it would come out of first gear pretty hard, like it had a shift kit. It is shifting very smooth right now. It has a leak somewhere but not a lot comes out. I just started using it as a daily driver 2 weeks ago. If these trannys are low on fluid do they shift smoother? Am I reading the stick correctly? Thx for the help. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: mysterious Tranny Question-Please Help.
Try sanding the lower part of the stick in a crosshatch pattern. It makes it easier to see the fluid level.
Rub the cross hatched area with soap stone and recheck the level, the clean fluid will show up better
Will d, thx guys. I can see fluid in the xxx'x just not above that level. I just don't want to run her dry. I think it was originally overfilled. They have a spot where excess fluid is expelled on the tranny right?
Yes, They have a vent, It would have to overfilled by over a quart of fluid to come out the vent. I overfill mine buy 1/2 quart with the trans HOT. Comes out to read at the max full line when cold.
good to know, thanks.
