Old 05-29-2003, 05:39 PM   #1
fryeguy2
Has anyone been able to fit 33's on their 3/4 ton?
I have a 71 3/4 ton GMC 2wd with rear camper overload leaf springs and it has coil springs in front. One of my buddies had the same type of truck, and said he fit 33 by 12.5 tires on it. But when i put on a set the back fit fine and the front tires wouldnt turn all the way because they hit the wheel well. Has anyone else been able to fit this size tire and if i lifted the front about an inch with rubber spacers, would i be able to fit these tires? They just barlely hit the fender. thanks.
3/4 ton 71 GMC 383 Stroker
fryeguy2 is offline   Reply With Quote
Old 05-29-2003, 08:24 PM   #2
BigBlack68
Negative Camber
BigBlack68's Avatar
I have 33x12.5 tires on my 3/4 and it turns without hitting fender
BigBlack68 is offline   Reply With Quote
Old 05-30-2003, 08:51 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I have 31's on my 71 C-20 and it gets close when turning the wheels but doesn't rub. NO way 33's would fit on mine.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
