![]() Join Date: Jan 2012
look what i found
so today i was at a guys place getting a dash pad for my 1980 gmc i bought off him from a parts truck he had, i was climbing over the pass side for the 3rd time (hes got a bunch of junk laying around) and i just happen to look over and i see this blue object, i look again and i think no way it cant be is that a bucket seat from a blazer
sure enough it is! im not sure if its from 73 and up style or prior im not too knowledgable on these seats, but from what i understand is the 73 and up the handle for flipping the seat forward is on the side, so what i think i found is a bucket seat from a 71-72 blazer with the highlander package, anyone know for sure what iv found? i only saw the one and couldnt find the other it started raining, im going to go back tomorrow oor sometime this week to see if he has the other, heres a couple pics i snapped of it, knowing my luck it will be from a 73 and up but still a cool find in my books |
Re: look what i found
Mid-seventies and not a Highlander plaid trim nor package that would be correct for a '72 Blazer.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
thanks tim, thats too bad i was hoping they were from the 69-72 but kinda thought they werent, would they even be worth getting?
If the frames are not rusted and the foam is useable. The foam can be worked and you can use 69-72 seat covers on them. I would not pay too much for them though.
72 Cheyenne Super 80 Silverado Blazer 2wd |
i didnt look at the seat frame but i can probably get them for free
VA72C10
![]() Join Date: Mar 2008
As mentioned, 73 up...bottom foam is 100% the same as 71-72. Back foam and upper frame are slightly different but with foam work the 71-72 covers will fit. Brackets are around 2" taller than the earlier ones....
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
could a guy just buy new foam for the earlier style and put it on instead of modifying the existing foam?
yes for about $400
what needs to be done to the original back foam to get it to work if i dont buy the correct foams
