Old 10-07-2012, 08:26 PM   #1
ubtripn
ubtripn's Avatar
What a day...now I have a strange front end noise
Just had new rims and tires put on, sounded fine for a couple of weeks and now when I am close to turning hard over to the right I get a sound that is hard to describe. It's like metal grinding over itself or some kind of metal grinding up against another piece of metal. I have the faster ratio power steering so it doesn't take long to get close to being all the way over. The sound is like a VERY old hinge grinding/popping. They did an alignment and I can see the shims and it didn't make this sound until today. It only happens when moving though, not when stopped and turning the wheel all the way over side to side. I have a new idler ar, tie rod ends, ball joints, pitman arm, I don't know what it is and I have hit the wall today. I lubed everything still have the sound. I hate working to find something all day and coming up short. oh well
ubtripn is offline   Reply With Quote
Old 10-07-2012, 08:50 PM   #2
72chevyk10
I built it
72chevyk10's Avatar
Re: What a day...now I have a strange front end noise
anywhere where the tires are rubbing?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 10-07-2012, 08:56 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Or the wheels on a control arm?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-07-2012, 09:16 PM   #4
sjarrett71
sjarrett71's Avatar
Are the lug nuts still tight?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 10-08-2012, 10:26 AM   #5
ubtripn
ubtripn's Avatar
Yeah, checked that.
Is it possible for them to put too many shims on top of the a arm while doing an alignment, causing metal to contact underneath the a arm. I can see a curved piece of iron there like half a dic shaped. it looks like recent contact is being made maybe when I am turning.
Old 10-08-2012, 12:59 PM   #6
ole dollor
ole dollor's Avatar
i would check the lug nuts first, if your truck has disk brakes look for rocks in between the disk rotor and backing plate...or a bent backing plate.....
ole dollor is offline   Reply With Quote
Old 10-08-2012, 01:03 PM   #7
no moa
no moa's Avatar
Pull the wheel off to start. See if there are any marks in the wheel. Got to be rubbing hard on the control arm or something.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 10-08-2012, 01:48 PM   #8
ubtripn
ubtripn's Avatar
Will do, I will pull the wheels tonight. Had em off 3 times yesterday, I hope I can find this.
Normally I ask myself - what is the last thing I touched, well I have drum brakes and I did adjust them I just don't see how that sound could be coming from inside the drum?
Old 10-08-2012, 02:08 PM   #9
custom1970
Member
custom1970's Avatar
while your at it, should check your wheel bearings just in case...
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 10-08-2012, 02:17 PM   #10
KEL
72 GMC
KEL's Avatar
wheel bearing was my first guess
KEL is offline   Reply With Quote
Old 10-08-2012, 03:20 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I had a drum brake adjuster come loose after a genius at a Les Schwab Tire Center screwed up 2 of my rear lugs and they had to pull the drum and brakes to get the lugs out with the axle still in the truck (long story). When Johnny Haha the tire ape, reassembled the brakes and didn't install the adjuster correctly it came apart while I was driving and wound up banging around inside the drum.
Did lots of damage to the drum, backing plate, and the shoes themselves. But before it was banging around... it was making the "metal on metal" screech. Then the "popping and banging" as you describe.
If it is a wheel bearing... the horrible noises are the bearings straining to come apart in their cages. Not to mention the damage that could be being done to the spindle if the truck is still being driven. I wouldn't drive it again until you pull that front end apart.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-08-2012, 03:24 PM   #12
ubtripn
ubtripn's Avatar
Sounds like I am going to be having some fun tonight then. I will also check/pack the bearings as well. I have never heard a bearing go so that just might be it.
When I adjusted the brakes I just expanded the shoes by turning the star sprocket (whatever it's called) a few notches to get the proper drag. I am going to rebuild them soon.
I know it sounds funny but drums almost serve me better in snow, don't know why but if I have them in good working order (and with the booster) they don't do too bad.
Anyway, thanks for the help!
Old 10-08-2012, 03:26 PM   #13
ubtripn
ubtripn's Avatar
I forgot to add. After I parked I pushed with my foot on top of the tire and it made the same metal popping sound but only one pop. Almost like metal binding somewhere but nothing is touching.
Old 10-08-2012, 03:44 PM   #14
GASoline71
GASoline71's Avatar
While you have everything apart... check the upper and lower ball joints too...
Gary
Old 10-08-2012, 04:00 PM   #15
ubtripn
ubtripn's Avatar
They are new but I will sure check them as well. Thanks.
