Old 10-07-2012, 11:39 PM   #1
Wvgearhead
Unisteer Steering U-joints
I am getting ready to hook up my steering on the 53. Has anybody used unisteer u joints? Seems they are priced good considering they are stainless.
I understand cutting costs in this are is a know brainer, but if they are good, why not.
Wvgearhead is offline   Reply With Quote
Old 10-08-2012, 12:10 AM   #2
parkwood
parkwood's Avatar
Re: Unisteer Steering U-joints
I have never used them but they seem like a good u joint, i always us Flaming river... Unisteer joints clamp on the shaft with a bolt where Flaming River has two allen screws with a locking nut to hold theirs on.. both a priced about the same..
parkwood is offline   Reply With Quote
Old 10-08-2012, 07:50 AM   #3
Wvgearhead
I think that last part come out wrong. I meant cutting corners on the steering is a bad idea.
The deal I have found on the unisteer is tough to beat. I would like to have flamingriver. Just wanted to hear if anyone has used them or have had problems with them. If the pinch style is better or not when compared to the set screw style.
Old 10-08-2012, 09:34 AM   #4
skip99
skip99's Avatar
I have them, they work fine, but are larger than flaming river, and I had to grind frame in a tight spot, if it was even an extr $20 ea. id use flaming river if I could do again..
or....I'll make you an even better deal on unisteer !
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 10-08-2012, 06:22 PM   #5
Scottshotrods
We use them alll the time here in our shop and we have well over 150 u-joints instock from Uni-steer.They are priced very fair and they are S.S and will not RUST.If we can help you out let us know?
Justin
805 485-0382
Justin
Scottshotrods is offline   Reply With Quote
Old 10-08-2012, 08:31 PM   #6
Wvgearhead
Thanks Justin, Has anybody tried sweet ujoints?
