Old 10-08-2012, 12:04 AM   #1
SnS C10
SnS C10's Avatar
some updates and a 4 inch front drop on the GMC
hey everyone. So, my engine that had been drinking a lot of water and mixing it in the oil is now running very good and strong. While cruising in first gear on my 3 speed sag, i can light up the rear end Only issue is now, there is a valvetrain ticking noise. not too loud, most noticable on engine deceleration in nuetral right before it gets to idle speed. tried over and over adjusting the valves and it wont fix it. so, since its not getting worse as of now, just going to run it and it runs awesome. I also replaced my front shocks this weeked. painted my rims and added trim rings. 2 tires, 2 rims, 4 trim rings and 4 center caps at 50 percent off day at the yard were 48 bucks!! also, i had a set of coil springs that i had cut years ago a total of 2 coils laying around. decided to try them out and it pretty low and it rides nice and feels much better in the corners as well. rear has a few leafs removed, sitting nice and raked how i like it. also finished welding my pipes 2.5" stainless exhaust with x pipe and 50 series flows. low and loud and lookin tough with the gmc front end....
SnS C10 is offline   Reply With Quote
Old 10-08-2012, 12:25 AM   #2
Square_78
Square_78's Avatar
Re: some updates and a 4 inch front drop on the GMC
Looks good! Love the GMC front end!
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 10-08-2012, 09:27 PM   #3
70blackfish
I just got this.... I like how low it is, but there are no springs in the rear.
70blackfish is offline   Reply With Quote
Old 10-10-2012, 09:07 AM   #4
BluTrukker
BOHICA
BluTrukker's Avatar
Had that same sound in an old car I had. Turned out to be a spun bearing.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
